Old 14-09-2006, 02:24 PM   #31
RG
Back to Le Frenchy
RG's Avatar
Originally Posted by xr8man83
well there you go you learn somfin new every day :
The 220 came out in june 01 in all the XR8's just to be precise.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2006, 02:31 PM   #32
RG
Back to Le Frenchy
RG's Avatar
Dyno sheet.
Old 14-09-2006, 05:35 PM   #33
bodes-sh
when they did the dyno run did they hook it up for a tune? or just a power run? someone correct me if im wrong, but don't they usually hook up a wideband o2 sensor to get the AFR's and make sure they are correct?
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 07:15 PM   #34
RG
Back to Le Frenchy
RG's Avatar
Well i just changed the oil and the spark plugs with some NGK Iridium one's (same as what was in there) and I tell you what it is a completly different car. All the plugs were fouled up and no.5 was not even finger tight. It doesn't ping anymore and it feels like it has a shedload more power. Amazing how something so simple can make such a difference. Also I somehow got the iridium plugs for $17.99 per 4 pack, everyone else wanted $21 per plug, I have a slight feeling that supercheap stuffed up.
Old 17-09-2006, 08:41 PM   #35
JC
Miami Pilot
JC's Avatar
Only sedans actually.
Ford Performance Club ACT
Old 17-09-2006, 08:42 PM   #36
JC
Miami Pilot
JC's Avatar
Good stuff. Bit easier than cutting out the unichip, hey. You'd think the guys running the dyno should have picked up on that.
Old 17-09-2006, 08:43 PM   #37
RG
Back to Le Frenchy
RG's Avatar
True, forgot to mention that.
Old 17-09-2006, 08:58 PM   #38
620hp_gt
620hp_gt's Avatar
On the same day that I picked my car up I had id put on the dyno. It came up with 130.5rwkw, slightly less than I was expecting. Now here is the problem, it is pretty much useless at anything below 3,000rpm if i've got the boot into it, takes off better at half throttle. Also it pings badly high in the rev rande in first and all the way through second with the boot well and truly buried. I've tried both optimax and ultimate and still i'm having the same issues, what could be causing this? The mods to it are in my sig, as you can see I really should be getting more power than what I am.
I brought my xr8 220kw new 0000032kms, I drove it 300km's from ford dealers in Adelaide to my home town. I took it easy for the first 150k's, after that i needed to know if it was speed limted.
Took it up to 240kph,first day, first two hours.
The next day, checked it all out and i was off to to our local Dyno, to test my brand new Car.
I was shattered. 143.2kw at wheels.
Replaced K/N filter 153.6kw's at wheels, still only average.
Fitted DnT Performance X pipe, free flow exhaust.158.6kw at wheels.
Today after many good trips it has 171kw's, Thats not bad, if it was a 6pack.
That same car has and will do 256kph on the SAT-NAV,210kph in fourth,runs out of speedo at 240kph, but keeps pulling hard to5400rpms in topgear.
Scary Fast, after 250kph's
620hp_gt is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 09:12 PM   #39
JC
Miami Pilot
JC's Avatar
171 at the wheels is around 240 at the flywheel, or 320hp - not too shabby for a 5.0 windsor, with no real major mods.
Old 18-09-2006, 06:59 AM   #40
620hp_gt
620hp_gt's Avatar
I think it's average,considering, a mate has a BA 4.olt, with the same rwkw's....FLASH TUNE AND EXHAUST ONLY. (his flash tuner worked well)
But my XR8 would hammer the BA any day of the week, just not on the Dyno.
My car does need an upgrade on the engine management, as still factory settings and computer.
I have some mates with BAGT's, twin brothers one each, and my XR8 is gone in 1st and 2nd.. But 3rd, it just cant hold them, their 3rd seems twice as stong. Not just one run, same everytime. Then the XR starts catching from 200kph+. (They have 230-242kw's at wheels)STD
Another mate has SV8 6speed, left that for dead, standing start.
My XR8 now has 75000 very hard country km's, and only had a water pump. THATS GOOD :
Old 18-09-2006, 07:33 AM   #41
620hp_gt
620hp_gt's Avatar
Oh Forgot the 6 set rear tyres.
Old 18-09-2006, 07:45 AM   #42
620hp_gt
620hp_gt's Avatar
When I ordered mine, you had to state you wanted 220kw motor.
They were both available.
I got the first 220kw delivered to Stillwell ford maybe even SA.
Liquid Silver, Black trim
Pedders Springs All round, from new.ORDERED
REGO XR8220, from new.
Momo wheel & shifter handle, from new.
Would Sell to right person.
Old 18-09-2006, 11:21 PM   #43
xr8man83
Grunt Files
xr8man83's Avatar
yea i just found out b4 in a thread i didnt realise that
xr8man83 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2006, 06:33 PM   #44
AUTickford
XD197
AUTickford's Avatar
Holy man sounds like the unichip has died. that power is way down on what it should b.You will b stoked when its sorted because it sounds like its a bit of a goer. So it made 175hp at the wheels? i only work in horsepower and at the tyres, not the old fashioned bhp which is at the donk not the tyres
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2006, 08:50 PM   #45
CAMS290
trying to get a leg over
CAMS290's Avatar
Where can I get this chip retuned?
Disconnect it and see if it runs any better
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2006, 06:48 AM   #46
RG
Back to Le Frenchy
RG's Avatar
How do I do that, just pull it out from the ECU? If I do that and it doesn't run any better can I just plug it back in?
