25-09-2006, 06:56 PM | #1 | ||
Apprentice Fridgey
Location: In a lil place called Gladstone aka. Glad2bstoned
has anyone put a 351 into a EB??? is this conversion easy or is there a lot of work to it? i have a 93 eb station wagon that my dad wants to convert into a drag car, i am able to pick up a running 351 and gear box for $1000, can anyone help?
96 EF Falcon Futura, Powered by Microtech, 2222549 Crow Cam, Metal Gasket, Port and Polish, Oversized Forged Valves, EF Fairmont Dash, K&N Highflow Filter, Pacemaker Competition Extractors, 2 1/2 Mandrel Bent Exhaust, High Flow Cat, Converter Shop 3500 stall, Shift Kit, 4.11 Diff Ratio, Mini Spool Best ET 14.654 @ 88.270Mph at Benaraby Raceway, Gladstone Queensland |
25-09-2006, 07:08 PM | #2 | ||
is the wagon a six or eight at the moment
25-09-2006, 07:09 PM | #3 | ||
Apprentice Fridgey
good ole six
25-09-2006, 07:12 PM | #4 | ||
windsor user
i'd send a pm to racecraft and eav8.... they've both done 351 into ea conversions, and should be able to help you out
25-09-2006, 07:12 PM | #5 | ||
it will be a bit harder then. but i got a street fords mag with a 351 EB XR8 in it, and because the 302 is the same block and all that as the 351 it slots straight in with all manifolds, (i'm pretty sure that's what the article said) so if you get an XR8 loom and computer it should all be sweet. even easier if you carby the motor
25-09-2006, 07:16 PM | #6 | ||
windsor user
ebfalcs.....the 302 from an EB is a windsor.
it is not the same block as a 302 or 351 cleveland it is exactly the same deal to convert a 6 cyl or V8 eb to clevo |
25-09-2006, 07:18 PM | #7 | ||
Apprentice Fridgey
its a 351 clevo carby fed, will be ripping all electrics out of it as nothing but light and ignition will be needed
25-09-2006, 07:30 PM | #8 | ||
1 question is it going to be used on the road
if so you wont be able to use a carby if not go for it jason
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
25-09-2006, 08:34 PM | #9 | ||
Apprentice Fridgey
it will be strictly for strip use
25-09-2006, 08:43 PM | #10 | ||
do it then if its only going to be used on the strip you can do what ya want without the road legals coming into play
1 thing though is if it gets into a certain time bracket on the strip you need to comply with a few racing specs there are a few good sites to look at but im not sure of the exact site addys but i will look them up for you if you want but im sure that if you did a search for drag racing in australia you will find all the info you require hope this helps jason
25-09-2006, 09:19 PM | #11 | ||
Apprentice Fridgey
i race my ef now, so yeah i know all the mods that need to be done and all the restrictions on times
26-09-2006, 03:11 PM | #12 | ||
keep us updated, sounds like a good idea. i was gonna do something similar. i was going to buy a injected 5litre windsor and through 351 internals.
26-09-2006, 06:37 PM | #13 | ||
1tufel, you can't do that. 302Ws will only take up to a 347ci stroke & bore. As for the rotating assembly, I'm unsure whether a 302C's rotating assembly is the same as a 302W or not.
26-09-2006, 09:03 PM | #14 | ||
Ghia5L, it wouldnt be. Bore and stroke may be the same, but isnt the windsor a 60 degree V? If it is, the crank pin 'timing' (for lack of a better word) would be different..
that said, i really, really want to see a 351W in an E-series. If a clevo can fit, surely a bigger windsor can. cya Ben |
26-09-2006, 10:48 PM | #15 | ||
windsor user
the 351 windsor block is different to a 302 windsor block...the 351 has a taller deck height to allow for the extra stroke....
its true that the 302 windsor block will only go out to 347 |
27-09-2006, 12:57 PM | #16 | |||
Oops, I slipped....
Windsor is a 90deg Vee, not 60deg.
Clevelands and Windsors are a fair bit different internally, not many parts interchange between the 2, and really, why would you, when there's unlimited amount of Windsor parts available from the US. Quote:
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
27-09-2006, 05:20 PM | #17 | |||
