Old 27-09-2006, 07:29 PM   #1
FORD EB 4.0
FORD EB 4.0's Avatar
Default Door snipper buttons removal.
Is it possible to remove ea/eb/ed door trims without snapping the arm that attaches the door snipper button, I think that is what the button is called. Any tips. :
FORD EB 4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 08:16 PM   #2
snypereb
[EBGLT]
snypereb's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
Got pics so we can understand what your talking about
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 08:19 PM   #3
LUXO_8
windsor user
ya need to pull the button upwards and off.......use some pliars with tape over the rough bits to grip them
then you can lift the doortrim over the shaft thing
Old 27-09-2006, 09:55 PM   #4
FORD EB 4.0
I gave the pliars a go ! but found the best way is once trim screws/interior door handle has been removed, lift the door trim up and pop the retaining clips so the door trim can be moved slightly away from the door, that will allow you to lower the door trim moving the snipper button up and then unscrew snipper until it can be taken off the thread.
Old 27-09-2006, 09:59 PM   #5
sphell
sphell's Avatar
Ford factory manual says to use pliers and a rag over the button.....that is the easiest way anyway.
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2006, 07:01 AM   #6
Holbrookau
OPT 20
Holbrookau's Avatar
From a couple of days ago..
http://www.fordforums.com.au/showthread.php?t=66706
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Holbrookau is offline   Reply With Quote Multi-Quote with this Post
