Old 07-10-2006, 09:08 AM   #1
scorpio39
Default AU heater control unit ( on heater house )
I am experiencing low cooling A/C ( 10 degrees ) due to no vacume at the heater control valve on the heater hose. This allows a mixture of hot/cold air when A/C is on.
I have closed the above valve using wire and the A/C temp goes down to 5//6 degrees.
Where is the vacume on/off controlled from ?
Should it be normally closed when everything is off ?
Many thanks in anticipation.
scorpio39 is offline   Reply With Quote Multi-Quote with this Post
