Old 14-05-2005, 09:55 PM   #1
InitialD
Low and Loud
InitialD's Avatar
Default Has My Auto Died?
Has my Auto Died in the ***????
Ive been having a wierd problem where the car has been holding in gears when downshifting from
2nd to 3rd in POWER MODE
3rd to 4th in ECONOMY MODE
i.e Even thou my foot is off the pedal, it holds 3rd and then 2seconds later jumps forward to 4th.
Now Tonight while driving home, It decided that 4th gear DIDNT EXIST in POWER or ECONOMY mode... like its a 3 speed? And when I slowed down it slammed hard when going from 3 to 2 to 1 BUT when i take off it shifts smoothly thru all gears BUT again NO 4th gear!!!!
Is this something as simple as a Inhibitor switch? Or Some other sensor? Or has my box died and gone to heaven?
I hope its not the auto, I do however have the Community 4 speed auto that I believe WAS owned by Sunny then karl, then Joel and now me... Hope its decent if I need it ;)
thanks out:
Old 14-05-2005, 10:06 PM   #2
NZ
NZ's Avatar
i never owned the auto. I simply sold it for sunny. when joel got it [put in apparently the trans guy told him it was the best ford 4 speed he'd seen. joel was really happy with the box. it might pay you to grab a copy of the workshop manual and read the trans section and grab a multimetre and sest some things. its a bit hard to diagnose over the internet.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 14-05-2005, 10:24 PM   #3
ilsautomotive
Former E-Series Member
CATman had the 3 speed problem, I can't for the life of me remember how he fixed it though...
Old 14-05-2005, 10:27 PM   #4
InitialD
Low and Loud
InitialD's Avatar
Was it 2 sticks of TNT and a lighter?
Old 14-05-2005, 10:31 PM   #5
ilsautomotive
What do you know, I found it. :d
http://www.fordforums.com/showthread...ghlight=mister
Old 14-05-2005, 10:36 PM   #6
InitialD
Low and Loud
InitialD's Avatar
Hmm Im using the ED Throttlebody with EB/ED/EF/EL style TPS. Now I recently changed it thinking thats the problems but it isnt! cause It was doing it with the old one and the new one.....
Old 14-05-2005, 10:48 PM   #7
InitialD
Low and Loud
InitialD's Avatar
Would HONESTLY the difference between running a ED Throttlebody with ED TPS instead of a DUAL TPS EA Throttle body be causing all this?
The ED TPS is simply wired up to the ECU TPS wires AND the TCU TPS wires.
It drove around Fine for weeks when i first converted to MPFI
Old 14-05-2005, 10:52 PM   #8
ilsautomotive
You should try my trans controller, Jase has it currently. He thinks it's the only one he's tried that actually works.
Old 14-05-2005, 10:56 PM   #9
InitialD
Low and Loud
InitialD's Avatar
Tried 3 trans ecu's so far and all with the same problems
Old 15-05-2005, 12:31 AM   #10
Sundeep
Sundeep's Avatar
Just put your other throttle body on Mick. Jeezzzuuusss! You're just making shit hard for yourself. I've done the "singly TPS spliced in to the other plug" thingo and it's stuffing up like yours, I get 4th at random. I can't wait to get the ED manifold in and use a dual TPS throttle body. Should run sweet.
P.S other thing you could check is shift linkage but I doubt it, sounds electrical.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2005, 09:23 AM   #11
NZ
NZ's Avatar
good luck unbolting the throttle body. those hex bolts are pretty hard to get to espcially the bottom two.
Old 16-05-2005, 01:13 AM   #12
InitialD
Low and Loud
InitialD's Avatar
Sundeep
your 100% Correct Sunny Ma Man! : turns out you are right, we took the car for a fang after the meet, and found it had all 4 gears. But as i drove the car and as it got hotter it was sorta holding gears abit. So.. off to get a Series 2 throttlebody and see what happens
Old 16-05-2005, 12:29 PM   #13
spope
spope's Avatar
Tell me about it - the whole piggybacking wires thing is just full of problems - ever since I did my mpfi conversion there have been niggling problems with gear changes - although I'm now running a Ghia auto computer which is magic. But still every so often it pops up a problem. Like, on the way home the other day it felt like it was trying to lock up the torque converter while slowing down - just really bizarre.
The sooner I convert completely to EB 2 engine management the better.
Mick: My car did specifically that when the wires for the trans tps weren't connected properly.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2005, 12:42 PM   #14
Gunns
Gunns's Avatar
This is just a way of your car telling you it wants a T5!
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2005, 01:02 PM   #15
Sundeep
Sundeep's Avatar
Told ya ****er...lol.
Sundeep
Old 16-05-2005, 01:02 PM   #16
Damo
awww nah but he has an auto license. lol. :hihi:
Hopefully changing the tps or whatever your doing fixes it.
Old 16-05-2005, 01:21 PM   #17
mcflux
mcflux's Avatar
Just want to add to this point, it definitely won't be the shift linkage because "D" is a single shift point on the box, the linkage doesn't move at all when it is in "D", it's all internal stuff like solenoids etc doing the gearchanges.
-Dave-
Old 16-05-2005, 02:06 PM   #18
InitialD
Low and Loud
InitialD's Avatar
LOL T5 is on the way.... I hope to have it in by the end of the year actually ;)
Old 16-05-2005, 02:38 PM   #19
mcflux
mcflux's Avatar
I could think of an alternative to a T5... :Reverend: lol
Old 16-05-2005, 02:42 PM   #20
InitialD
Low and Loud
InitialD's Avatar
LOL still requires a good working auto dude ;)
Old 16-05-2005, 02:45 PM   #21
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
my grandfathers auto NC had a similar problem... he didn't have third... 1st 2nd 4th... needed a reco..
cheers
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2005, 03:21 PM   #22
mcflux
mcflux's Avatar
It was worth a try :
Santo: (off topic) yes, I *will* post pix soon... I'll look for a charger tonight after work (promise!)
-Dave-
Old 19-05-2005, 11:33 PM   #23
InitialD
Low and Loud
InitialD's Avatar
Thought Id post up how its going......
Its all FIXED
It turned out it was the EB2/ED throttlebody with the moddified TPS wiring. Doesnt work. Sunny was correct :( lol (after telling me 10 times to do it)
MY average has dropped to 14.0 flat even with me booting it everywhere AND the car takes off better.....
