Old 25-05-2007, 04:56 PM   #1
Stav
Smile
Stav's Avatar
Default Top speed in 3rd with an auto and the 1/4mile
Does anyone know what speed an auto can be held in without changing into 4th under wide open throttle?
I read that in economy mode the base au six can go to 175 kmph before changing.The xr range changes at 150 kmph.
In power mode the base ford au six changes into 3rd at 179kmph the xr models change at 167 kmph.
Does this mean that the base car has better shift points for the 1/4 mile stint over the xr and can run a stiffer diff ratio without problems?
Old 25-05-2007, 05:05 PM   #2
5L
[ 5L ]
5L's Avatar
the fact the xr changes sooner, is due to the higher diff ratio. xr's actually rev out higher than base models.
www.ignitionimages.com
Old 25-05-2007, 05:12 PM   #3
Stav
Smile
Stav's Avatar
If I ran 4.3 diff ratio what would I need to do to have t right for the 1/4 mile? Also what can we do with the edit to help?
Old 25-05-2007, 05:15 PM   #4
xr8ute
Back on the road
xr8ute's Avatar
It all depends on the gearing Stav, and how your shift patterns have been programmed (edit)....assuming they've been changed from std?
Wheres your rev limiter? At what rpm is your car shifting from 3-4 at WOT?
The reason the base AU Forte, and XR have different speeds for gear shift is because of the different diff ratios.
I am crossing the line in third, at 99-100mph, at just under 5500rpm with the 3.91's. I need to shift the gearbox manually so that it doesn't shift up too early.
Old 25-05-2007, 05:30 PM   #5
The Monty
Just slidin'
The Monty's Avatar
Im pretty sure the Fairmont (AU1) changes right on the limiter, so 179-180 in non econ mode. Thats for me anyway.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 25-05-2007, 05:30 PM   #6
Stav
Smile
Stav's Avatar
I used to cross the line at 4700 rpm at 92.7 mph 149 kmph. Assuming a 4.3 ratio from my 3.73 it is a 15% change. I would cross the line at 5405 rpm for the same mph.The 4700 rpm is not the meat of my power in third.Power peaks at 5000 rpm.Bulk of power is at 4700 to 5400 rpm..Rev limiter is 6000rpm.
If I put the car in third for the run will it still change up to 4th or will it hold it more?
Old 25-05-2007, 05:32 PM   #7
Stav
Smile
Stav's Avatar
I might have to modify the box by reading its wiring diagrams to guarantee the box will be locked in 3rd.
Old 25-05-2007, 06:55 PM   #8
eXi7w0unD
eXi7w0unD's Avatar
my stock i6 does 150 in 3rd lolz.
i usually go to 40 in 1st then change, when i hit 70-80 i change to 3rd. im a nut.
i won.
eXi7w0unD is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2007, 08:36 PM   #9
Stav
Smile
Stav's Avatar
Can the auto be taken past the normal change up speed by somehow holding 3rd gear across the line and hence avoiding fourth gear?
Old 25-05-2007, 09:07 PM   #10
EFFalcon
Last warning
EFFalcon's Avatar
it should hit the limiter.
work out what speed you're doing when the rev limiter kicks in.
thats what 3rd will rev to :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 25-05-2007, 09:33 PM   #11
Stav
Smile
Stav's Avatar
Hmm 6000 rpm limiter with no speed limiter.So holding the gear lever in 3rd should go to the limiter then?
My rev limit is 6000 and no speed limit
Old 25-05-2007, 09:49 PM   #12
Stav
Smile
Stav's Avatar
The wagon will pull 5500 - 5800rpm across the line.It may hit the limiter at the line actually.I get it to 6100 rpm then.ehe
Old 26-05-2007, 11:24 AM   #13
stiddy
stiddy's Avatar
If you leave it in third it wont shift, it will just keep going till you hit the rev limiter in that gear, which would be around the 160km/h mark maybe?
thats weird, even with a manual before I had my diff gears done I was crossing the line in 3rd at about 5500-5800 or a little more which was around 150km/h, sometimes I hit 3rd gear limiter on the line or a little before it.
Old 26-05-2007, 11:28 AM   #14
Mechan1k
Mechan1k's Avatar
If you lave it in 3rd it will stay in it ... and not shift up to 4th ... I have tried it with it locked in 1st and in 2nd ... and it doesn't shift up ... and i leave in locked in gear.
I suggest manually shifting it when racing ... it will hold it longer in the gear than just leaving it in D in power mode.
Old 26-05-2007, 12:36 PM   #15
Stav
Smile
Stav's Avatar
This is good news.With a 4.3 or 4.11 ratio the wagon would miss the rev limiter under wot then get held in third for crossing the line where it would hit the speed limiter for a theoretic 13 second pass at 100mph. Nice.
Old 26-05-2007, 12:41 PM   #16
Mechan1k
Mechan1k's Avatar
Just make sure you have the right speedo gear ... other wise the ECU likes to cut it out earlier ... also you can get a Limp Home Mode Defender box installed as well (I didn't realise there was one until I saw one the other day.)
Jase found out the hard way the other week ... was set to crack 13's after new axle and shorter diff in it ... went from 3.23 to a 3.89 from memory) ... hit speed limiter ... fule cut and ECu went into LHM/Guard mode and wouldn't rev over 3K RPM ... not happy.
Oh well .. next time ... he still managed a 14.2 after hitting fuel cut and coasting over the line very slowly ... so there was definitely a 13 in it.
Next time I guess.
Old 26-05-2007, 12:44 PM   #17
Stav
Smile
Stav's Avatar
The speed limit can be raised with the edit tune and so can the rev limit. Any cut outs should then be eliminated.Dont you think?
Old 26-05-2007, 12:45 PM   #18
Mechan1k
Mechan1k's Avatar
True ... true.
That's the next thing he has to do (as he is still running factory tune)
Old 26-05-2007, 12:49 PM   #19
Stav
Smile
Stav's Avatar
He will do well and it should also help my wagon to do a bit better.
Old 26-05-2007, 01:05 PM   #20
Mechan1k
Mechan1k's Avatar
Especially if power is still being made at redline ... if you can extended the relatively short redline it will help ... how much did you get your shift-points altered with the tune??? Or just get line-pressure increased with it???
He needs to save up a bit of rego now ... all in good time I guess ... and there's a set of MT's he is going to run with next time as well ... and increased redline (as he still making power/torque at rev-limit as is now).
Old 26-05-2007, 01:14 PM   #21
Stav
Smile
Stav's Avatar
I dont know? i did install black speedo gear for the 3.73 I am running. Still the speed was out by 5 odd percent. I drove the car in first today to check my redline and its confused me a bit. Tacho show 6400 rpm and a second tacho showed 6150 rpm in first.So I geuss it may be at 6150? i am getting this checked soon to be sure.
Old 26-05-2007, 01:41 PM   #22
Mechan1k
Mechan1k's Avatar
Run the dash diagnostic ... the digital readout for the speedo and tacho seems more accurate than the analog gauges (I have been doing testing recently myself with it) ... the digital speed readout matches my GPS reading on the highway ... analog is about 2 kays out.
Old 26-05-2007, 03:35 PM   #23
xr8ute
Back on the road
xr8ute's Avatar
the std tach in the dash is pretty innacurate in my experience as well.
it shows 5800rpm when it hits the limiter, while datalogs from the "clean tacho output" pin on the EEC show 5500rpm as the limit.
Old 27-05-2007, 04:22 PM   #24
Casper
Contributing Member
Casper's Avatar
that makes no sense to me Stav. Ive got shorter diff gears than you do and I've got a 95mph timeslip (almost 153mph) and I'm not even close to maxing out 3rd gear. In fact, based on my calculations I can rev 3rd in mine (with 4.11's) to 101mph (over 160kph).
Older, wiser, poorer.
Old 27-05-2007, 04:27 PM   #25
ratter
ratter's Avatar
tyre heights may be making a difference
Pit Lane Performance
Old 27-05-2007, 04:46 PM   #26
Ruger
Bseries Moderator
Ruger's Avatar
26" tall tyre 3.7's in the bum and 3rd gear in the auto (1.00) youll be doing well over 100mph.
If you hit the limiter in third somethings odd (or youve put a hairdryer under the bonnet :P)
EDIT: Stav - Before you outlay some money there is a program called gearcalc. google for it and itll answer all your questions better than any of us can.
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2007, 04:50 PM   #27
Ruger
Bseries Moderator
Ruger's Avatar
Yep when you use the 1 2 3 D method your not holding the gear but rather locking out the next gear - i.e if you leave it in 2 your locking out 3rd and 4th but the auto will still shift normally through 1st and 2nd What you can do is put it in D start racing, then when its in second or third and you want it not to upshift just move the lever back one spot to '3' and it wont shift up again.
Just manualise the auto ;)
Old 27-05-2007, 05:14 PM   #28
eXi7w0unD
eXi7w0unD's Avatar
any 1 can drive auto but to drive stick in an auto.. thats takes skillz
i won.
Old 27-05-2007, 07:28 PM   #29
Stav
Smile
Stav's Avatar
Casper have patience for me.This gear stuff I just havent been getting..I am trying to understand it. How far can the wagon pull with 4.3 or 4.11 diff across the finish line.? What revs did you see across the finish line? The 3.7's still are no match for the first gear of a manual 5 speed box.
Old 27-05-2007, 07:35 PM   #30
Casper
Contributing Member
Casper's Avatar
Well, at 95mph I'm only doing about 5100-5200rpm from what I could see. No more than 5300rpm certainly. Theoretically I worked out that 101mph was more than possible with my 3rd gear now. Thats fairly screaming for an I6 NA over the 1/4, I doubt I'll ever get there.
