Old 19-06-2007, 03:51 PM   #1
ILLaViTaR
ILLaViTaR's Avatar
Default Torque wrench reading wrong???
I bought a $45 wrench from autobarn and it hada little plastic thing that sat inside a hole on the side of the the torque wrench.
That has now gone missing, it still clicks but is it reading right?
I need to tighten up my exhaust manifold and according to the wrench they needed around 1/2 a turn.
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 04:05 PM   #2
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
exhaust manifold.... just tighten it up
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 05:18 PM   #3
klawsterfobik
Bad Music and Litre Bikes
klawsterfobik's Avatar
If its plastic, I can't see it being used it the torque settings of the torque wrench. Mine hits metal on metal so that it doesn't get dinted or and change the settings.
Does anything hit or touch where the plastic thing was? Did it stick out at all?
XY Wagon - NAKED!
Originally Posted by Gammaboy
Anyway. Enough reality, back to the topic.
klawsterfobik is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 07:46 PM   #4
webby_191189
low wagooon
If you have been using it to undo bolts it may be out of calibration.
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 08:48 PM   #5
accurate1
The little plastic plug covers the adjustment screw used for calibration. As long as you don't move the screw it should be reasonably accurate.
accurate1 is offline   Reply With Quote Multi-Quote with this Post
