Old 22-06-2007, 11:05 PM   #1
mik
mik's Avatar
Default traction control?
just wondering if any one had tried fitting traction control to an au2 xr6, my young brother borowed my car today and mentioned it when he returned the car (hopefully he was`nt bagging them up). anyway i thought it would be nice for wet roads , any fairlane guys any comments on traction control ,good or bad, my bro is a computer tech he seems to think just by changing the abs module and connecting to a single wire under the dash it should be a goer and running a cutoff switch to the console would be fairly easy,
any feed back appreciated.
Old 23-06-2007, 01:03 PM   #2
mik
mik's Avatar
anyone??
Old 23-06-2007, 01:40 PM   #3
robbo_yobbo
Kick out tha Jams
robbo_yobbo's Avatar
I dont know if its that simple.
I thought traction control killed the injectors if wheelspin was detected, so I dont know where the ABS system comes into it.
traction control wont help you accelerate any faster by preventing wheelspin, but there are other benefits to it
$416.80.......All that cash came from a new (used) car. Check your back seats!
robbo_yobbo is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2007, 03:24 PM   #4
HLC
Audi S3
its crap.
i hate it.
when the car detects wheelspin, it cuts fuel supply.
so think of it this way, your car starts to slide on a wet road, so normally youd keep on the gas and control it. TC cuts the fuel, often leaving you in a hairy situation/position.
i always turn if off in the wet.
Old 23-06-2007, 04:11 PM   #5
bodes-sh
at low speed it can also brake the wheel that is losing traction, but how it tells which one is i don't know, probably just relative speed compared to the other one
Old 23-06-2007, 04:20 PM   #6
zetec
Zoom Zoom
zetec's Avatar
Originally Posted by HLC
its crap.
i hate it.
My apologies but that has to be about the stupidest attitude I've ever heard to traction control. Keeping on the gas in the wet to power on through it? Leaves you in a hairy position?!! Give me a break, traction control stops you losing control when your hero status runs out on a tight corner and also protects your licence if there happens to be a cop behind you and you inadvertantly lose traction around a wet corner. It's a licence saver, a life saver and there's nothing else to it. It's your choice to turn it off, but honestly, I hardly think it was designed to kill your fun and make your car harder to drive, quite the reverse in fact.
Typical rear wheel drive mentality. Rain = dorifto. What a hero.
And before you bag me for driving a front wheel drive (that happens to have both traction control and stability control), I regularly drive rear wheel drive turbos in the wet with TC and I can assure you that it's not a bad thing. No point trying to be a hero and turning it off, one day you'll go too far and the consequences will be something altogether different.
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2007, 04:58 PM   #7
jones_aus
jones_aus's Avatar
i agree with zetec...
tc is definatley a good thing.
jones_aus is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2007, 10:50 PM   #8
mik
mik's Avatar
the main reason for looking into this was, last week while turning right onto a busy road in the wet with a constant barrage of traffic, it was difficult to get away off the mark without sitting on the spot spinning wheels taking needless time in middle of the road even with gentle throttle control getting no where, another thought came to mind, traveling on highway wet night on cruise control 100kph hit a slippery spot and suddenly stepping sideways with no warning, ...... i had this happen to me, ok thanks guys for replies, i will look further at whats involved in adding this feature, more plusses than minuses i think .
cheers mik
Old 23-06-2007, 11:02 PM   #9
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
another thing that increases safety on the road , gets a Tick from me !
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2007, 10:51 PM   #10
zetec
Zoom Zoom
zetec's Avatar
cheers mik
It will almost certainly involve a new engine computer, or at the least a reflash to the stock unit. The ABS system will possibly need to be upgraded to include new sensors too. You might find this interesting http://autospeed.drive.com.au/cms/article.html?&A=1121.
Chances are it's not going to be cheap unless you can find a wrecked AU with the feature fitted.
2012 Mazda3 MPS
Old 25-06-2007, 11:45 PM   #11
Umineko
Karasu
Umineko's Avatar
Most of the time you don't notice it's there and when you do notice it, you're glad of it
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2007, 11:54 PM   #12
FGII-XR6
FGII-XR6's Avatar
the traction control is in the ABS unit and wires back to the ECU there is an input to the ECU for this but it's not a simple matter of bung in the ABS unit and one wire I look into it and although it is doable it is involved and if you have LPG you have to put a relay in to disable it whent it is on gas as it is not compatible with LPG systems even factory
Old 26-06-2007, 01:33 PM   #13
sleekism
1999 Ford Fairmont Ghia
sleekism's Avatar
The Traction Control is crap and doesn't work by the time it kicks in you are already sideways it only really works if it's wet at an intersection and your going dead straight and even then I hate the clunk it makes as it slams on the brakes on for me it cant be doing any good.
The BA/BF traction control seems to work better but then again I really dont like the level of big brother they seem to have.
sleekism is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2007, 01:42 PM   #14
MRJUCY
Fordless
MRJUCY's Avatar
The AU traction control needs the 4 chanel ABS from the upper auto models, manuals & lower spec models got 3 chanel.
MRJUCY is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2007, 08:37 PM   #15
EF Futura 07
14.915 @ 151 KPH
EF Futura 07's Avatar
: ? theres only one reason you dont like traction control, and that is you want to be a hero at evey green light and spin that open diff of yours :
it does not kick in once you have got sideways, that only happens when your rear wheels loose traction. traction control AKA "Traction Control" is just that.
it controls the slipping due to the loss of traction. and no it is not harmfull to your car, other wise they wouldnt make it to start with,(90% of car makes now, have traction control) what it acually does is 2 things. 1:cuts power to the spinning wheel and transfers it to the other and 2:brakes the spinning wheel(this is where the ABS comes in(stops the wheel its braking from locking up)). it also works the best when your car is warm(so on a cold start up it may seem ****) do a test, try taking off full throttle in the wet with it turned off (you will just sit there and spin one wheel,gradually start moving) turn it on and you will acellerate like normall, with no wheelspin... :togo:
And like other people have said, one day your going to wish you had it turned on :
:evil3: 96 EF2 Futura I6 Auto :evil3:
EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's : , XR6T Snorkle/Fram Filter, 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD, 5% Tint, Sony Head Unit/ 6 1/2 Inch 190w Speaker's
: 14.915 @ 151 kph 60' 2.254 :
EF Futura 07 is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2007, 09:56 PM   #16
mik
mik's Avatar
thanks for the replies i will look further into it_2:
