Old 29-06-2007, 02:06 PM   #1
ILLaViTaR
ILLaViTaR's Avatar
Default Instrument cluster Question on price
I'M considering upgrading my low series cluster in my ED falcon classic to a Mid series sports cluster (I dont think I can get a high series).
Problem is I see them for $60 each.
Is that a reasonable price?
I thought they would've been around $30-$40
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2007, 02:26 PM   #2
sexr6tasy
A reasonable price is a price your willing to pay for one.
sexr6tasy is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2007, 03:00 PM   #3
ILLaViTaR
ILLaViTaR's Avatar
Yeah the only reason I want it is for the tacho and oil pressure (which is half the cluster lol).
It looks hard to wire up and I'm unsure how to connect additional wires to the battery terminals since they're already grouped into 2 big terminals and not tonnes of little wires.
Old 29-06-2007, 04:31 PM   #4
wiggum_04
long live wagons
wiggum_04's Avatar
$60 is a good price if u can get a cluster with smartlock on it as i have seen them go for around $100 on ebay. $30-40 is wat you can expect to pay for a non-smartlock cluster. you dont need to do any wiring for it apart from changing over the oil sender unit. they all have the same connections so just plug in and away you go( except there will be antother little connector for the smartlock)
cheers, dan
EB II Falcon Wagon
EL Engine, ANZ FTR 16's, Lukey 2 1/2" Exhaust System, Clear front indicators, EL Taillights, EL door trims.
Soon to have: Lowered to super low height
wiggum_04 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2007, 10:28 PM   #5
Schmee
Schmee's Avatar
since your car is an ED it will just plug and play all you have to do is change the oil pressure sender over.
all other items on the dash will work...(recently did this to my EB 2 )
and as stated above by wiggum 04 just make sure you get a smartlock cluster
there are 2 main plugs for the cluster and one small one seperate for the smartlock
Kev
Kev
Schmee is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 12:36 AM   #6
ILLaViTaR
ILLaViTaR's Avatar
I heard you need to run a wire to the ignition coil to get the tacho going???
Also there's another wire needed for low wiper fliud but I really don't need it.
I also heard I need to run a wire from the positive battery terminal for the volt reader.
Old 30-06-2007, 01:08 AM   #7
WillsEDfalcon
WillsEDfalcon's Avatar
is there a wiring diagram floating about on the forums somewhere? gotta do the same thing to mine.
Cheers,Will
dynamic white ED falcon
- was stock as a rock.
WillsEDfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 01:17 AM   #8
jjj
jjj's Avatar
That's only for the EA models(Tacho) and it's a pink wire up near the brake booster that you have to splice into. If you got an EB series II upwards and get an s-pac dash from this model it's plug and play (everything works except) as said before you need to fit an oil sender as the oil switch you have will show FSD (full scale deflection) on the oil pressure gauge.
Cheers......
jjj is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 02:40 AM   #9
ILLaViTaR
ILLaViTaR's Avatar
Excellent looks like i'll pick one up soon.
Also where is the oil sender located on the engine and how much? (from wreckers or cheapest)
Old 30-06-2007, 04:37 AM   #10
jjj
jjj's Avatar
It's down on the block between the dizzy and ign coil roughly speaking, probably $10 from the wreckers if that.
Old 30-06-2007, 10:21 PM   #11
ILLaViTaR
ILLaViTaR's Avatar
hmmm. How would I get to that, it was a enough trying to put the lead back onto the coil form the dizzy cap.
Do I have to remove the manifold?
Old 30-06-2007, 10:44 PM   #12
Schmee
Schmee's Avatar
the best way to get to the oil pressure sender is from underneath the car
the sender is located about 3 inches to the rear of the block from the dizzy
not the easiest to get at but not too hard just a bit akward
no need to remove the manifold at all
Kev
