Old 12-07-2007, 09:02 PM   #1
CMYAU3
Tyre Shredn
CMYAU3's Avatar
Default Stereo Troubles
some times when i start my car the radio turns on but there is no sound,
and after about 2 minuts of driving it will sound will come out.
the bit i dont get is some times when this happens
( radio turns on but there is no sound )
i turn the fan on and then the sound works,
or if i wiiiiind the window down the sound also comes back on.
( sorry cant speel )
has it got somthing to do with the air pressure in the car when i gat in .
and is it just me.
ive got all standard ford stereo ..........forte
all that has been added is a 10" response sub n amp in the boot with a line level converter. and that was all intalled proffesionally. over year ago
CMYAU3 is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2007, 10:09 PM   #2
robbo_yobbo
Kick out tha Jams
robbo_yobbo's Avatar
sounds like maybee your amp on/off switch wire is either loose or shorting out somewhere, or hooked up to the wrong power wire..... (im assuming with this theory that all speakers are run through the amp?)
$416.80.......All that cash came from a new (used) car. Check your back seats!
robbo_yobbo is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2007, 10:12 PM   #3
CMYAU3
Tyre Shredn
CMYAU3's Avatar
to tell u the truth. ive got no idea
Old 13-07-2007, 12:00 AM   #4
robbo_yobbo
Kick out tha Jams
unplug the power cable to the amp - if you can still hear your speakers when the radio is on, then the problem must be in the head unit itself (or maybe the plugs just not pushed in the back properly) if the sound cuts out when you kill power to the amp, then the likeley culprit is what I discribed above.
I actualy thought of one other possible cause... Theres a nokia mobile phone wiring loom that I think came standard in either the fairmonts or fairlanes (or both) and I think all the other models still had the plug, but the loom came loose in the boot.
The loom is designed to kill volume to the radio when the phone rings, so maybe this plug or loom is shorting out.
If you have the loom plugged in, its got a vibrant blue plug on it and a tag that says Nokia/Ford Mobile blah blah something and plugs somewhere under the dash near the center facia - get the multimeter onto it if you can find it next time the radio plays up if the problem doesnt turn out to be anything to do with the amp.
Old 13-07-2007, 12:58 AM   #5
JC
JC's Avatar
Good theories, but my bet is that at least one of the speakers is starting to fall apart. Happened in my parents AU2 forte, and all I did was replace the dodgy speaker, and the radio has not lost volume since.
Ford Performance Club ACT
Old 13-07-2007, 01:08 AM   #6
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
i had the same problem and mine was as JC stated one of my front speakers was falling apart and earthing out. Spent up on some nice alpine splits and walla problem solved!!!
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2007, 01:43 PM   #7
robbo_yobbo
Kick out tha Jams
lol, every time my cars had a problem, its been some way out over the top obscure cause, so Ive grown a tendancy to overlook the simple stuuf lateley.
That stung me the other day though, I completeley stripped down and rebuilt a motorbike because it wouldnt start, and for the life of me couldnt find the problem, only for my girlfriend to walk up and say "should this switch be like this" - the kill switch was off - lol :
with only one speaker gone though, you would still get volume to the other speakers though (i would have thought)- unless the sub installer rewired them in series for some strange reason.
Old 13-07-2007, 08:29 PM   #8
CMYAU3
Tyre Shredn
CMYAU3's Avatar
yeah great idea my front left is playn up a little and i have been meaning to replace the standard speakers anyway.
Old 13-07-2007, 10:15 PM   #9
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
i recommend the 6 inch alpine Z series splits! they come with the mounts to put them in the ford holes but you have to find some were for the cross overs. If you know a little about them its easy other wise pioneer do a really good 5x7 inch speaker that fits straight up to original holes. I put them in the wifes car there about $150 against the alpines are getting towards 300. Fusion do a 5x7 for the fords to not sure how good they are though. And there held in by fords little security bolts!!
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 13-07-2007, 10:18 PM   #10
schuldiner
security bolts that you can undo with a 5mm socket:P
Everything always works out when you just do whatever you want and don't worry about the consequences.
see my ute here
AU parts for sale
schuldiner is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2007, 10:26 PM   #11
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
there you go. You learn something everyday. I already had a set of the security sockets so didnt even try.
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 13-07-2007, 10:52 PM   #12
schuldiner
i dunno if its 5mm but if you mean the bolt heads that are like the reverse torx key then yeaha 5 mm(or so) socket will undo those no worries, i went to bunning and supercheap and everywhere olooking for the tool, then just decided id try the socket and whaddya know it worked.
see my ute here
AU parts for sale
Old 13-07-2007, 11:20 PM   #13
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
yeah there the ones i was talking about. i didnt even think to try a socket. I got my little set from Autobarn i think its just a rail with about 12 different sizes on it. Its was about 4 years ago i bought them but they were only about 40 bucks i think.
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 13-07-2007, 11:33 PM   #14
schuldiner
don't worry mate i'm good at finding the dodgy way to do things:P, yeah i tried few places couldn't find any, just your regular torx key's, oh well the socket works fine they aren't tight enough to strip the head off em so its all good might invest in set just in case though. cheers for the info.
see my ute here
AU parts for sale
