Old 25-05-2005, 10:15 PM   #1
EL_futuraistic
EL_futuraistic's Avatar
Default does a ef lsd bolt straight into el??
hey guys.
I have found a EL Fairmont LSD for sale. Will it bolt straight into my EL futura which only has the standard single spinner???
Are all the ratio's teh same?
EL_futuraistic is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2005, 10:17 PM   #2
niko
likes falcon's
niko's Avatar
your ef ss diff will most likely be 3.08:1 ratio. the el lsd your getting will be either 3.23/3.27/3.45:1 depending on how lucky you are, it also should say on a little tag!
it "should" bolt up with no mods, am i correct in saying this guys?
www.carhubsales.com.au
Old 25-05-2005, 10:19 PM   #3
Psycho Chicken
Psycho Chicken's Avatar
Ratios will be different. 3.45 for the LSD unless it's be played with and the Futura will be 3.08 or 3.27.
And yes it'll bolt straight in.
Oh wait, it's not a Ghia, might be 3.27? Check the tag/sticker.
Old 25-05-2005, 10:29 PM   #4
EL_futuraistic
Default ok
Ok, cool.
I found it on ebay, it only says fairmont. I take it everything should run ok, even though it may have a different ratio.
Old 25-05-2005, 10:46 PM   #5
fairmont1998
fairmont1998's Avatar
The one on ebay is an EF diff and is 3.23 ratio according to the seller.
The EF and EL housings have sight differences. There are different mounting holes for the top arms on the EL and the watts link pin is lower on the EL.
It should still bolt into an EF but if the watts link doesn't line up you can change diff hats to use your original.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2005, 12:53 AM   #6
Psycho Chicken
They will still bolt up though. All E-series 28 pinion diffs swap over, it's just the brakes that become an issue.
Old 26-05-2005, 01:46 AM   #7
arm79
arm79's Avatar
The watts link can be solved by getting the el one...
But since the bolt holes for the upper arm on the EL are lower and further back, you would have to get the EL arms as well. Using the EF arms would throw out the diff angle a little wouldnt it.
arm79 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2005, 01:57 AM   #8
Psycho Chicken
Isn't there two sets of holes for the lower arms? I know there's something similar on EBII/ED diffs.
Can't be hard to get the EL bits anyway.
