Old 29-07-2007, 06:24 PM   #1
fordzatmyplace
B Series XR8 Pilot
Default Header Tank Help
On ebay there is a brand new header tank, but it looks like its for a base model and dosen't have a low coolent sensor hole. My car has the low coolent sensor, so my question is, can my sensor be fitted to this header tank with no hole??
Is that a BULGE on your bonnet? Or are you just happy to see me?
WANTED EB-EL V8!!
http://www.fordforums.com.au/showthread.php?t=11242992
fordzatmyplace is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 06:46 PM   #2
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Got Pics .. or a Link for that matter ?
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 06:54 PM   #3
b2tf
not here much anymore
b2tf's Avatar
Nup. Has to have the hole in it, or youd have to add one.
2024 F150 XLT
Old 29-07-2007, 07:37 PM   #4
fordzatmyplace
B Series XR8 Pilot
here is a piccy lifted straight from ebay.
It looks like there is a thread in hole where the sensor normally goes, so i have to drill a hole then screw the sensor in yes??
WANTED EB-EL V8!!
Old 29-07-2007, 07:39 PM   #5
b2tf
b2tf's Avatar
yep pretty much, just going to have to make sure it holds pressure.
2024 F150 XLT
Old 29-07-2007, 07:45 PM   #6
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
how clean does that look!
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 07:50 PM   #7
fordzatmyplace
B Series XR8 Pilot
hmmm. Got any tips for drilling the hole and sealing it adequately?? He’s got a tank with a sensor already in it but that’s twice the price :
WANTED EB-EL V8!!
Old 29-07-2007, 10:05 PM   #8
Davo3460
mate just use a small hole saw and use all the fittings off the old tank works fine did just recently
Davo3460 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 10:10 PM   #9
howesy
howesy's Avatar
They also have the unit with a new sensor.
http://cgi.ebay.com.au/FORD-AU-HEADE...QQcmdZViewItem
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 10:15 PM   #10
b2tf
b2tf's Avatar
honestly if you can stretch it, go for this one. i have doubts as to whether any aftermarket fitting etc or drilling a hole in would hold the pressure.
2024 F150 XLT
Old 30-07-2007, 01:21 AM   #11
Mechan1k
Mechan1k's Avatar
No real need to use one with a sensor ... you should be checking under bonnet often enough to make sure it is OK ... I seem to do fine without one on my ute.
Also ... B-series header tanks fit nicely as well ... I know ... I have one in the AU.
Just need the B-series middle radiator hose from the front of the header tank as it is different from the AUs.
I pciked mine up from the wreckers for about $35 2nd hand ... looks like new.
Old 30-07-2007, 01:41 AM   #12
howesy
howesy's Avatar
Don't know about that, I check under the bonnet all the time.
Last week was driving along and the sensor light came on. Pulled over straight away to find a breached radiator core.. have had a car without a sensor that did the head gasket before you knew you had a problem because once the water drained below the temp sender the guage (with no water around the sender) shows not too hot at all. When the tank sender indicates your water level is still well above the highest point of the engine and quick action can avert much expense. I may have been unlucky but I reckon the tank sensor saved me this time and I feel much more comfortable with one but each to their own.
Old 30-07-2007, 12:51 PM   #13
JC
JC's Avatar
The AU6s have failsafe cooling, so even with a breached radiator, the car will operate OK with no water - it basically shuts down cylinders and the transmission goes into Limp Home Mode to avoid damage. Looking at the temp gauge, as well as the high temp warning would do the same job as the low coolant level indicator.
As of rthe original question - Every tank has the screw in fitting, just some have a hole and some dont. If you drill the hole and swap all the bits over from your old tank, it will work like one that already had a hole.
Ford Performance Club ACT
Old 30-07-2007, 03:03 PM   #14
Fairlane
V8 Powaah
Fairlane's Avatar
No offence guys but that Ebay is a rip.
I paid $43 and got a new one from Ford- nonsensor
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 03:57 PM   #15
sly
Sly like a G6
sly's Avatar
Failsafe doesn't work if you have a non-SVI LPG system. I have had a constant battle with coolant leaks around the LPG system in mine, despite changing water hoses and hose clamps. My last attempt at a fix was to smear clear RTV silicon inside the hose ends before clamping. So far so good, but when the leaks start the header tank can empty in a couple of days. Usually the first sign of trouble is the aircon stops working. I'd love to retrofit the sensor to my car, that might be the next project.
Also, I had a top hose rupture in traffic while running on LPG. Luckily the bloke in the next lane spotted the coolant running out from under the car and called out to me. I switched to petrol to get somewhere safe to pull up, and the temp gauge never moved from 'O' (in NORMAL) the whole time.
Sleeper, anyone?
Old 30-07-2007, 04:02 PM   #16
sly
Sly like a G6
sly's Avatar
Heavy eathmoving gear (trucks, dozers etc) is rigged with tank sensors for exactly that reason. In fact they shut down the engine when the level gets too low in the tank. It can be a PITA sometimes but it beats $250K+ for an engine swap.
Sleeper, anyone?
Old 30-07-2008, 09:36 PM   #17
jug69
Just a quick question.Can you wire in a level sensor for an AU2 XR6 that doesn`t have one,that is,is the loom hidden somewhere and be tapped into?I also feel safer having one,has saved me on earlier models.
jug69 is offline   Reply With Quote Multi-Quote with this Post
