Old 29-05-2005, 04:16 PM   #1
niko
likes falcon's
niko's Avatar
Default engine conversion- ef into xf
have complete motor, thinking of putting into an xf
besides radiator and thermo's wat else needs to be done, car is running gas research so ecu and injection system not required
www.carhubsales.com.au
Old 29-05-2005, 04:24 PM   #2
LUXO_8
windsor user
possibly this shud be in X series forum???
you'll need XG engine mounts to start with.
what gearbox is in it? if auto get the bellhousing off an EA 3 speed.
Old 29-05-2005, 04:25 PM   #3
niko
likes falcon's
niko's Avatar
nah has xg t5 in it and an eb 3.45:1 lsd
and its ef motor :P
Old 29-05-2005, 04:25 PM   #4
LUXO_8
windsor user
ah ok
you can possibly run the EF BBM, you'd need to work out somethnig to switch the runners....
doing this may enable him to keep his current gas mixer..... mounts very similar to the XF EFI one
Old 29-05-2005, 05:12 PM   #5
INJECTED_250
Custom user title
INJECTED_250's Avatar
u will need to modifie an Xe dissy, pretty sure all u do is use the gear of the ohc motor on the Xe dissy, and re-drill the hole for the role pin.
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2005, 05:45 PM   #6
niko
likes falcon's
niko's Avatar
hmm cool, he's already using an xe one to run the gas
