Old 26-09-2007, 05:12 PM   #1
mustie's el
Default Writen Off
hey guys this week was going to be the week were i sent my spare el head away to get work done to it for a bit of extra flow, now my el is outside covered and written off after a 66 year old drunk decided to drive into me while i was outside my car, luckily the two rh side doors were open and i was in between them, so the car took most of the impact, anyways on to better things now i guess i bought an el xr8 to help me recover hehehe should arrive this week hopefully, white manual lowered body kit ftrs, looks very clean except for suspension issues does anyone know whether the i6 diff and suspension fit onto the xr8 as the control arm and other suspension components have been hit and bent on the xr8 i was hoping i could just change over thanks for your time, kind regards mustie
mustie's el is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2007, 06:08 PM   #2
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
A bit of Bad Luck and a bit of Good Luck..............
V8 Front Suspension is more heavy duty that 6 cylinder Suspension but pretty sure its a straight swap......
Same as the Diff
As eveyone buys random diffs off Xr6's and Xr8's to put in their std Falcons so I cant see why a std Falcon diff wont fit in and Xr6 or Xr8
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
