Old 01-10-2007, 07:00 PM   #1
ayeyew
Teh Baest
ayeyew's Avatar
Default Sluggish on start up
For the last week or so my AU has decided that sometimes when it starts up it wants to sit on around 200-400rpm and shake pretty bad, lol
Doesn't do it all the time, just every now and then.
Today i went to start it up and it nearly didn't start at all (took about 5 secs to fire up) and then it went with the whole shaking thing
It is an auto and it kinda feels like it is stalling??
Ideas?
All i have been doing to counteract this problem is starting the engine and revving her up to about 1200 for about 30 seconds, then she is fine
She is getting her 140,000km service done on Wednesday so prolly shouldn't worry that much, just wondering what it may be?
I'm thinking either Fuel Pump or injectors or sumn??
Seems to work fine at all other times tho, just not on start up.. Im pretty sure it's firing on all 6 cylinders.. I HOPE
1999 Liquid Silver AU
Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!)
Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler
Coming..CMS Stg2A Cam, 68mm TB
Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220
Currently:
151kW (165 on other dynos )
ayeyew is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2007, 08:10 PM   #2
ayeyew
Teh Baest
ayeyew's Avatar
Also, only things i have added to my car in the last month is a K&N Panel Filter and an XR6T Wide Mouth Snorkel
Don't think either of those would be responsible for this
Currently:
Old 01-10-2007, 10:05 PM   #3
EF Futura 07
14.915 @ 151 KPH
EF Futura 07's Avatar
HI, could be a blocked fuel filter. try resetting computer
:evil3: 96 EF2 Futura I6 Auto :evil3:
EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's : , XR6T Snorkle/Fram Filter, 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD, 5% Tint, Sony Head Unit/ 6 1/2 Inch 190w Speaker's
: 14.915 @ 151 kph 60' 2.254 :
EF Futura 07 is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2007, 10:16 PM   #4
Kryton
Kryton's Avatar
Nulon carby and throttle body cleaner is your friend.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2007, 04:23 PM   #5
ayeyew
Teh Baest
ayeyew's Avatar
Where exactly is the throttle body? I really don;t know too much about cars
I might buy some of this cleaner stuff and give it a go
Currently:
Old 03-10-2007, 04:33 PM   #6
Kryton
Kryton's Avatar
follow the black plastic tubing that goes from the airbox to the engine, when the end of the plastic tube gets to a metal bit, that is the throttle body.
remove the black plastic tube from the throttle body and do as the can says.
Old 03-10-2007, 04:38 PM   #7
ayeyew
Teh Baest
ayeyew's Avatar
Champion! I'll head down to repco and get some of that cleaner stuff
If that doesn't work, any other suggestions? Check my spark plugs?
Currently:
Old 03-10-2007, 04:41 PM   #8
Kryton
Kryton's Avatar
give the Nulon a try first otherwise id look at fuel filter, leads and spark plugs if you havent done so already.
oh, enjoy the smell of the throttle body cleaner too.....no really, its awesome!
