Old 05-11-2007, 12:01 PM   #1
azzrock
Default noisy engine
my 98 au has a rude noise coming from the engine. i thought it was one
of the pullies making this noise so i removed the flat belt. no noise.
all the idle pullies around the tensioner seem ok.
the water pump pully does not spin that well so i think its the problem.
can i just change the pully with out pulling the pump out.
thanks
azzrock is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2007, 12:34 PM   #2
Fairlane
V8 Powaah
Fairlane's Avatar
100% on the tensioner pulleys?
My car started sounding like it had a supercharger. It was a cactus tension pulley (The plastic one).
Would be surpried at a water pump pulley though. Can anyone answer his question?
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2007, 12:37 PM   #3
azzrock
thanks mate ill have another look. mine sound like its a electric motor
Old 05-11-2007, 01:37 PM   #4
FGII-XR6
FGII-XR6's Avatar
the tensioner is the main candidate you can get the bearings cheap enough and they are a weak point. take the belt off and try spinning the different pullys by hand just to be sure at this low speed it may show nothing but worth a try.
Old 05-11-2007, 03:07 PM   #5
86caprirs
Canadian User Inside
So when you removed the (flat?) belt, you ran the engine and the noise was gone?You said the water pump pulley was hard to turn? It could be the water pump bearing it self starting to sieze. I would checked the idler and tentioner pullies just to make sure 100% that they are still good.
1995 F-150 5.8L XL 6" TC lift on 35" Pro Comp A/T
2008 F-150 5.4L XLT
Technician for Ford of Canada.
86caprirs is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2007, 05:09 PM   #6
azzrock
the idler pullies seemed ok. the water pump pullie wasn't hard to turn just didn't spin freely. im going to check them again.
thats every one for you input i am very greatful.
Old 05-11-2007, 05:38 PM   #7
azzrock
i just rechecked the pullies the tensioner pullies seem ok. they spin freely and have very little play(is that axil play) i really hope it is the tensioner pullies. the water pump
flang look like a to clean up for the new gasket.
