FULLY XR6
HI ALL
Can someone please advise or recommened what size hi flow injectors that i can use on my ef xr6. The car moves along quite well just trying to get bit more grunt thanks sam fully out there rippin all over dum holdens ![]() ![]() ![]() |
Performance moderator
![]() Join Date: Feb 2005
XR6 injectors are the same as base models...
If its lean then add alittle fuel pressure... In most cases Ford engines run rich... Higher flowing injectors would require an ECU re tune...
