Old 14-12-2007, 12:12 PM   #1
brad`
The Monty
brad`'s Avatar
Default AuI 2000 Fairmont door problem
I have a Series I AU Fairmont and the Power Window controls on the drive side vibrate hardcore, and one know how to take of the door trim ? i trided the four or five screws around the out side and its like it stuck near the door handle some where but no sure how it comes off.
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2007, 12:45 PM   #2
blackers10
blackers10's Avatar
lift the window controls UP (start from the front edge)
there is a screw directly DOWN in that hole
also behind the little circle just infront of the door handle
good luck
Old 14-12-2007, 01:07 PM   #3
brad`
The Monty
brad`'s Avatar
behind that circle thing just in front of the handle i dont have a screw, i got a bolt that needs a socket set to remove you mean that one ? also how do i take off the window controls? u mean the hole box thing, between the trim and the handle ? i tried a screw driver but i didnt want to force it off
Old 14-12-2007, 01:09 PM   #4
blackers10
blackers10's Avatar
yeah to take the actual door off u need to undo that bolt
its a 10mm
the power window controls(where the lil switches are to make hte window go up and down)
it just clips in with a metal spring clip thing.. just lever it up from the front i think it is.. may be the back .. its pretty hardy lil bugger so you shouldnt snap it
then just use flat head screwdrivers to pry the switches out (Theres little lugs that they clip into on the sides (you will see them once its out)
then the switches the selves clip onto the other bit the same way
then the metal rocker will be accessible.. this is what needs cleaning and underneath it (it gets carbon on it)
Old 14-12-2007, 01:42 PM   #5
brad`
The Monty
brad`'s Avatar
hey, thanks man i got it all off, now jutst gotta clean it all, got any ideas on whats best to do that with ? thanks for ya help again means alot
Old 14-12-2007, 01:43 PM   #6
blackers10
blackers10's Avatar
i ususally just scrape it off with a screwdriver coz its only carbon..
or you can get some CRC CO Contact Cleaner i think its called
Old 14-12-2007, 02:18 PM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
carby cleaner works a treat
just take the switches fully out of the door and away from the electrics first
Old 14-12-2007, 04:22 PM   #8
brad`
The Monty
brad`'s Avatar
Awesome, stoped the vibration windows work awesome again no lagging haha, now i need a new Window switch for the back passanger side. i think there like $35 - 40 soi dont mind to much
Thanks for the help guys
Old 14-12-2007, 04:31 PM   #9
blackers10
blackers10's Avatar
did you break one?? lol
happens i spose
i think my front left motor is cactus :(.. window went down but not up again GOD DAMN!! lucky for me.. i have aircon WOOT
