Old 04-02-2008, 11:58 AM   #1
sandman_au
Truck Driver
sandman_au's Avatar
Unhappy 88 KE TX3 Died
Had probs with car stalling when stopping at lights etc for a while & recently while driving (not always under load) it began to splutter like it was out of fuel? Until it finally just cut out & rolled to a stop.
Thinking either electrical or fuel obviously but seem to have fuel getting through.
When the car stalls i found a relay on the floor behind computer was clicking sort of like a flasher unit sound (& hot). Auto elect said it could b a number of things making relay cut power?
Changed plugs leads & awaiting a dizzy cap 2day (cuz its wornout) then will test 4 spark before heading to coil.
Ive read about the ignition module in forum? Not sure what that is cuz havnt got any repair manual.
Its only an old workcar now so dont want 2 spend heaps just need it back on the road to get me to work.
Any ideas much appreciated & thx in advance.
sandman_au is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2008, 05:15 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
if it is an EFI there will be a fuel relay inside the car that should tick
also an engine managment computer
have a look on the fuel rail and see if there is a fuel pressure regulator on the rail
replace the fuel filter if not already done
if it is carby seek out Vippen or a 88 KE TX3 owner
My car goes Brumm Brumm
Old 04-02-2008, 05:17 PM   #3
dirty hands
Over Thinker
if it is a dissy module the car wouldnt start at all in most fords the module
works or it doesnt
it is inside the dissy a throw away item
Old 04-02-2008, 05:47 PM   #4
sandman_au
Truck Driver
sandman_au's Avatar
Sorry. . . . Yes its an EFI 1.6 motor.
Replaced the filter within last 12 months & seems to have fuel still running through it.
Still waiting 4 the damn dizzy cap from auto1 but it hasnt arrived 4 some reason.
Old 04-02-2008, 09:20 PM   #5
dirty hands
Over Thinker
best guess and diy
if the dissy doesnt fix the problem and you still get the clicking
get to a wrecker replace the unit making the noise
then if no better again that engine managment computer itself
Old 05-02-2008, 08:35 PM   #6
sandman_au
Truck Driver
sandman_au's Avatar
Well i got a new dizzy cap 2day & it seems 2 fit with same dimensions as old 1 i had to replace. . . . new leads etc then i went to try the ignition & had fingers crossed to get it started.
BUT, you wouldnt believe it. . . . . the DAMN battery has gone flat & hasnt enough power to get it turning over : :
Got it on charge now for a while & then i can find out if its gunna start or at least find out if im getting spark. Then i can either relax or chase down another avenue :
Will keep you posted on the outcome as it progresses (hopefully not much futher) just incase it helps someone else out there with a similar problem.
BTW, i used firing order of 1432 that i read in other posts - hope its right used:
Old 05-02-2008, 09:45 PM   #7
dirty hands
Over Thinker
yes thats right but i still recheck myself
make sure rotor is near number one lead on the cap / number one cylinder on compression stroke / and the timing mark is near TDC
Old 25-04-2008, 06:00 PM   #8
graham7773
Default firing order
My laser manual says 1-3-4-2
graham7773 is offline   Reply With Quote Multi-Quote with this Post
