Old 06-02-2008, 11:50 PM   #1
kcej
2mny projects 2 lttl time
Default Help Please_AU Engine Diagnostics
Tried "the workshop" but was ignored bigtime. Shoulda tried here first
I have an AU3 that I bought damaged.
Seemed to idle fine, start easy, but had a flat spot on acceleration
In the two weeks I've been driving it daily, the miss has gotten worse. Also, it now takes four or five seconds and a pump to start where before it was instant, with no need for pedal
Guy at work blamed dirty injectors, but before I pull em out, thought I'd ask here.
I have a complete car that I can go the "swap a part at a time" elimination route with, but where to start, and in what order, considering both
1..likelihood as a cause
2..work involved in swapover
injectors?....coil pack?....some of the sensors?
Help please.......Keith
kcej is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2008, 12:17 AM   #2
BeStRaFe
lpg = big boom!
BeStRaFe's Avatar
check the leads...
BF Futura Dedicated E-GAS w/Ghia bling
Project: 86 ZL Fairlane, Red, Sunroof, 310,000KM
BeStRaFe is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2008, 07:50 AM   #3
FGII-XR6
FGII-XR6's Avatar
leads coil pack and plugs are a good start
Old 07-02-2008, 08:20 AM   #4
kcej
thanks guys I'll start there
Old 07-02-2008, 08:20 AM   #5
mik
mik's Avatar
i`d be changing the fuel filter as well just in case.
Old 07-02-2008, 10:13 AM   #6
EvilChief
Boost Addict
spot on
buy urself a little spark tester for about 15 bucks, with this you will be able to test the strength of the coils, if u feel fancy remove coilpack and test your primary and secondary circuits for resistance. a coil with less resistance on teh secondary winding can indicate an internal short.
also measure the resistance of all spark plug leads with an ohm (multi) meter, if they are all under 15kohm
look at spark plugs, is the gap right, correct heat range, is the electrode burnt, are they sutty, etc
once all ur ignition components check out fine, check for fuel pressure (both at idle and under load, if fuel pressure drops off you may have a dying fuel pump, check fuel filter on much crap is in it, last but not least fuel pressure regulator, use a pair of pliers to clamp the return line for the fuelrail and do the fuel pressure test again.
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 07-02-2008, 10:53 AM   #7
aye you
The Origional, The Best
aye you's Avatar
my moneys on the leads and coil pack
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2008, 11:33 PM   #8
kcej
Thanks everyone.....I'll post the results after I find the problem tomorrow;-)
