Old 07-02-2008, 02:05 PM   #1
poolkeeper
Its Resonating!
poolkeeper's Avatar
Default Problem urgent!!
On the way home on the motorway, the back end off my car made a sudden vibrating noise and it was slowing my speed down pretty rapidly. Vibration can be felt through the car. Something hitting the tailshaft??
But then it goes and comes back again?
Going over bumps doesnt really trigger the vibrating/rubbing..
I had a quick look under there, cant find no grinded marks or anything.
I need the ute for work tommorow 5am!!
HELP ME PLEASE..
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2008, 02:18 PM   #2
Eu-GenixX
Eu-GenixX's Avatar
check the exhaust... mine basically split in half at the front muffler yesterday afternoon and had similar symptoms....
check the exhaust... push on the tail pipe.. see if the rest of the exhaust work moves in different directions...
other than that... now sure.... and also.. mine is a sedan...
Eu-GenixX is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2008, 02:46 PM   #3
poolkeeper
Its Resonating!
poolkeeper's Avatar
Just jacked it up for a proper look.
The only things I noticed were..
Tailshaft has about 1-2mm play when in neutral...
Oil on the rear seal of the transmission, I know my trans is slowly dying and I did replace that rear seal a year back, but I doubt this is the problem. When the vibration happens nothing cant be felt through the transmission.
Also had it running on the jack stands to about 80ks nothing, that was the speed I was doing on the motorway.
Old 07-02-2008, 02:48 PM   #4
rag top
rag top's Avatar
Uni joints?
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2008, 02:48 PM   #5
Scott
Does it do it under throttle, back off, rolling or all 3?
Scott is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2008, 03:07 PM   #6
poolkeeper
Its Resonating!
poolkeeper's Avatar
What do you look for when looking at the uni joints Michael??
It does it all 3, GT006.
Just went for a drive to investigate and try source the problem, but nothing was a miss.
Old 07-02-2008, 03:22 PM   #7
Stav
Smile
Stav's Avatar
My god..it sounds like my broken rear wheel studs!! Do you remember when my 5 wheel studs broke clean off?? Take the back wheels off and check them.Is the tailshaft moving alot in the gearbox rear extension housing?
Old 07-02-2008, 03:22 PM   #8
Racecraft
they call me Tibbo
Racecraft's Avatar
wheel nuts... check them asap..even if it isn't them per say you might have broken a stud or two.. tighten those bad boys up and eliminate them from the equation
Old 07-02-2008, 03:36 PM   #9
Scott
Studs are a good guess, I would also be checking that there is oil in the diff.
Old 07-02-2008, 03:36 PM   #10
poolkeeper
Its Resonating!
poolkeeper's Avatar
Yep I remember that, do you mean up and down movement in the gearbox rear extension housing Stav?
"Out to check wheel nuts"
Old 07-02-2008, 03:45 PM   #11
Scott
Come on, how long does it take?
Old 07-02-2008, 03:53 PM   #12
poolkeeper
Its Resonating!
poolkeeper's Avatar
I can see a pattern emerging, both rear lock nuts are now like rusted and have snapped on me??
Wheel nuts are tight.
Old 07-02-2008, 04:09 PM   #13
poolkeeper
Its Resonating!
poolkeeper's Avatar
About 1mm play - in/out, up/down and left/right in stud axles, that is ok isnt it??
Alot of surface rust on them though
Old 07-02-2008, 04:13 PM   #14
Scott
Do you have that same play on both sides?
Old 07-02-2008, 04:16 PM   #15
rag top
rag top's Avatar
"A bad U-joint can most commonly be detected by a metallic clunking sound when the vehicle is placed in gear. This indicates play in the U-joint and should be investigated as soon as possible. Other symptoms of a failing U-joint are vibrations from the drive shaft, noticeable especially between 25 and 35 mph; shudder on acceleration and/or squeaking noises."
Soruce: http://autorepair.about.com/cs/doity.../aa102602a.htm
Old 07-02-2008, 04:26 PM   #16
poolkeeper
Its Resonating!
poolkeeper's Avatar
The drivers side (where most of the vibrating is coming from, I think) has abit more play left to right, about 1mm more.
Nope I dont really have any of those symptons above, just the normal noise when you put it into drive etc. What 25-35mph in kph, around 60-70??
Old 07-02-2008, 04:38 PM   #17
xrfalcon
On The Limiter
xrfalcon's Avatar
Maybe a axle bearing might have colapsed, take a bit longer to check tho
xrfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2008, 04:43 PM   #18
rag top
rag top's Avatar
Try this site for a few more ideas:
http://www.babcox.com/editorial/us/us50126.htm
30mph is 50kph (roughly).
Old 07-02-2008, 04:44 PM   #19
Werd.
nou
Like 50-60kph
Werd. is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2008, 04:47 PM   #20
JOSH
JOSH's Avatar
is there an egg in one of your back tyre's
JOSH is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2008, 05:13 PM   #21
poolkeeper
Its Resonating!
poolkeeper's Avatar
no egg in tyres.
The problem hasnt happened the last 3 drives Ive been
You think its ok drive to work tommorow?? then book it in and get it checked??
Old 07-02-2008, 06:12 PM   #22
Scott
no egg in tyres.
You won't get egg in your tyres until you have had chicken in there first. Have you checked to see if you have oil in the diff? I'm suprised by the play in the rear axles, that suggests a collapsed bearing but you would hear it all the time.
Old 07-02-2008, 06:54 PM   #23
poolkeeper
Its Resonating!
poolkeeper's Avatar
Havent check the diff yet, never done it before.
Is it just undo the bottom bolt and if it leaks out, there is enough in there- on level ground???
Old 07-02-2008, 07:06 PM   #24
Scott
^^ No, there is a bolt on the cover where you would fill it up. Take it off and stick your little finger in there. If you're finger gets wet it has enough.
Old 07-02-2008, 07:08 PM   #25
poolkeeper
Its Resonating!
poolkeeper's Avatar
whoops yeah I meant the filler hole, bottom hole wtf haha
Old 07-02-2008, 07:24 PM   #26
Stav
Smile
Stav's Avatar
Right hand side eh? Brake shoes? Wheel bearing? A bolt pieced the tyre? Check the pump up suspension.
Old 08-02-2008, 06:47 PM   #27
rag top
rag top's Avatar
How did it go today? Play up at all???
Old 08-02-2008, 09:24 PM   #28
poolkeeper
Its Resonating!
poolkeeper's Avatar
All was fine no problems at all
Ive come to the conclusion that 1 of he handbrake shoes dislodge and was bouncing around and stuff in there.
thanks for helping me out guys
