05-03-2008, 04:03 PM | #1 | ||
Car: 2001 AUII Futura Classic
Problem: Instruments intermittently dying on me. LCD trip meter in the centre bottom of view goes blank, rev counter, speedo, fuel and oil temp guages freeze in place. Problem lasts whilst I drive - the following morning they're ok again. Rebel Ford Diagnosis: Car in today - they tell me there could be a dry joint or problem on the circuit board driving the gauges. New instrument cluster $750 + labour + resetting odometer? Anybody got a more cost effective alternative? I'd really appreciate some help here. |
05-03-2008, 04:18 PM | #2 | |||
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Try contacting site sponsor FTG Autosalvage
2024 Audi RS 3 Sedan - Mythos Black 2024 Ford Mustang GT - Vapour Blue (built 31-10-2024 - on "TIJUCA" ETA mid-Feb '25) 2023 Skoda Superb Sportline Sedan - Steel Grey |
05-03-2008, 04:40 PM | #3 | ||
Thanks for the advice mate...this seems reasonable.
I found a reference to instructions on removing the cluster at http://www.aufalcon.com/aufalcon.htm , then looking under "workshop" for an article explaining how to remove the cluster. Unfortunately the weblink no longer works; I think the website address was changed. Anybody got a new link to this article? |
05-03-2008, 04:58 PM | #4 | ||
not here much anymore
Dont have a link but provided you're careful it is easy to do.
At the top of the cluster there's 2 plastic plugs, carefully prise these out and you'll see 2 philips head screws. Undo these, then carefully prise the cluster out, making sure you get the actual cluster and not just the plastic fascia in front of it. The easiest way I've found is to pop out the fuel door/boot release buttons (they just pull out) from the dash, and then wedge a long screwdriver up behind the cluster and carefully prise it out that way. If you've never had it out before, it can be pretty firm and hard to get moving, but once you've got it on it's way, its a very simple process. Obviously refitting is the reverse.
2024 F150 XLT
05-03-2008, 05:04 PM | #5 | |||
All Bran = Regular Member
http://www.fordforums.com.au/vbporta...article&id=305 |
05-03-2008, 05:17 PM | #6 | ||
Thanks for the quick help guys!
Can I simply use any AUII cluster? |
05-03-2008, 05:56 PM | #7 | ||
Audi S3
yep. should be a straight swap.
06-03-2008, 10:12 AM | #8 | ||
Next upgraded Mk1 Leopard
When you get it out check the cable conections, soem of the wires may be 'lose'. turn the keys to just before you start the engine, move the cable and see if any of the lights come on/off.
Uncle Ken
06-03-2008, 12:20 PM | #9 | ||
Hey Uncle Ken,
Do you mean my problems may simply be related to a loose wire? (rather than a bum unit) Since the problem is intermittent I guess the best time to do this is when it's not working? Murphy's Law - it's been fine all the way home from the Ford Dealer and all the way to work today! |
06-03-2008, 02:00 PM | #10 | ||
I just know I thought my door locks had gone but having spent a weekend pulling of all the door trims checking and then replacing them I pulled out the cluster unpluged/pluged and hey presto all good. If you have a go leave the cluster out and drive around the block (carfully of course) and keep an eye on the cluster. If you are lucky it might just be a lose conection
UK
06-03-2008, 03:13 PM | #11 | |||
Walking with God
GK
06-03-2008, 03:24 PM | #12 | ||
Hey guys,
My cluster has stuffed up too so i bought one from ebay and the seller was from a wrecker and had tested it and everything and it worked properly (according to them). But it doesnt' light up when the headlights are on, the right indicator doesn't display but it click and works, and the tacho jumps as it increases but is normal when decreasing. Does anyone know if it is just a fuse or something along those lines. I have pulled out and swapped the fuse in the fusbox below the steering wheel and unplugged the cluster and reconnected it too??? thanks guys look forward to your suggestions. P.S. everything works other than that |
06-03-2008, 06:01 PM | #13 | |||
formerly PURSUIT-250
Also with sticky tach needles, you will find the needle base is touching the display facia, you might have to lift the clear plastic of and then with two screw drivers lightly lift the needle up a little, enough so it won't touch the facia. This happened to mine only in warm weather, and after a 20min drive at night when the instrament light's where on, it heated the facia lightly warping it enough to make the needle stick. cheers mick. |
07-03-2008, 12:23 PM | #14 | |||
11-03-2008, 03:31 PM | #15 | ||
It's now four days since the "problem" was diagnosed, and I've driven the car on three out of the four days doing about 200km....NO PROBLEMS?
"Knock on wood", it was a dodgy connection that got inadvertently "fixed" when the Ford guys pulled it out and stuck it back in! |
11-03-2008, 03:54 PM | #16 | |||
Walking with God
There are some wires that need cutting from the right plug and connecting to pins on the cluster. Pain of a job. I had mine working okay but the "new" cluster had a faulty temp gauge. I haven't got around to having another go at it. GK
12-03-2008, 11:06 AM | #17 | ||
Oh yeah you read my mind!! I want to take it to an auto electrician but I just needed to know exactly what was wrong with it so they don't charge me an arm and a leg. Thanks for the input, I did swap the low series with the XR version. They only had the XR ones on ebay so yeah. Thanks for that, I'll get a professional to do it. Does anyone know of a good auto electrician on the Gold Coast???
