Old 28-03-2008, 04:12 PM   #1
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Which Spark Plugs
Hi All
I have a 6/2000 AUII with Factory Dual Fuel. I don't know which type of spark plugs to buy. The NGK website tells me that BPR6EY's are the go, which are 0.8mm plugs whereas the petrol equivalent is listed as the BPR5EY-11s which are 1.1mm gap.
What is the difference, and which one is right?
Old 28-03-2008, 05:41 PM   #2
Chamelion
I used NGK ZGR6B11 in my AU3 Forte on LPG. This plug was reccomended by Torquegas. I'm rather happy with them. Much better than the Ford supplied Iridium plugs that were in last time.
These ZGR6B11 are only $2.75ea at my local CarBitz.
Matt.
Chamelion is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2008, 08:25 PM   #3
bodes-sh
normally ngk petrol plugs, you can gap them down if you want, i have standard ones in mine at 1.1mm gap and haven't had any issues with backfires, etc
Old 28-03-2008, 09:22 PM   #4
InfernoSR
Sales Representative
InfernoSR's Avatar
I was told that the Dual Fuel runs better with the shorted gapping, also found in the XR6... which is what i ended up using anyway... :P
Old 28-03-2008, 10:49 PM   #5
bodes-sh
apparently the petrol plugs perform better than the recommended lpg plugs, so i'd just get them and gap them down to 0.8 if it concerns you
Old 28-03-2008, 10:53 PM   #6
Mr Hardware
okay, sounds interesting
seems i currently have Denso .8s that are recommended by denso for AU1 LPG motors... but not AUII. I don't see that there's any difference between one AU silvertop and another, is there?
Old 28-03-2008, 10:59 PM   #7
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
I have used both the BPR6EY and the ZGR6B11 in my taxis, wasn't looking for high performance or anything just no backfiring
Found no real difference between them, if I recall they changed the recomended plug halfway through the AU range but both worked
The "5" and "6" in the number is the heat range with the 6 being a cooler plug recommended for gas
I always used .8mm gap as well, whatever plug type
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2008, 07:41 AM   #8
GK
Walking with God
GK's Avatar
My gas guy always uses the normal recommended petrol plug gapped to 0.8-9.I tried gas plugs myself but they made the car run like a dog. I've used the stock plugs (non-iridium) since.GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 29-03-2008, 06:39 PM   #9
EvilChief
Boost Addict
little sticker on underside of bonnet recommends plug gap, which IIRC is 1.1 for petrol.
gapping down from factory specs is only done, when ignition issues arise under high boost application.
most NA cars run 1.1 to 1.5 gap, most turboed cars run 0.8 to 0.9 gap (as a rule of thumb, but check factory specs)
simply gapping down a plug does not neccesarily mean better power or economy, in many cases it does quite the opposite. a smaller gap produces a smaller spark, which in turn then cause not fully burnt air fuel mixture, hence shitty economy and power.
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 29-03-2008, 06:51 PM   #10
PoweredByCNG
PoweredByCNG's Avatar
Dedicated LPG engines should be running spark plugs with a smaller electrode gap (< 1.0mm) and one heat range colder than petrol plugs.
Regards,
Dave
PoweredByCNG: Sick and tired of all the ignorant 'gas is crap' comments out there.
PoweredByCNG is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2008, 09:39 AM   #11
Mechan1k
Mechan1k's Avatar
I tossed my Iridiums (too expensive) ... and went with standard NGK's gapped down to 0.8mm
Much cheaper ... works a treat ... so far I have managed just over 20,000km without a hiccup yet ... so looking good for my dedicated LPG ute.
Old 01-04-2008, 01:20 PM   #12
blueoval
Critical Thinker
blueoval's Avatar
I havent come across having to replace spark plugs yet, but when I do I'll make sure I get correctly gapped ones to suit dual fuel.
Is there a plus that suit dual fuel applications rather than just one or the other?
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
