Old 11-04-2008, 09:31 PM   #1
rockoz
Default AU auto help
Hey guys I really need some help. Mates AU had some slip in reverse when I drove it. Not a lot. Next day got worse. Now he has had to rebuild box for 2g and replace radiator for another g. Guy doing work said it should have thrown a warning on dash for overheating. Do Fords need tech reset for things like this? Would such a warning have stayed?
Would really appreciate some help
rockoz is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2008, 03:17 AM   #2
The Monty
Just slidin'
The Monty's Avatar
It will just show up when the error codes are scanned, but I doubt many people do that very often anyway once the car is out of warranty.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 12-04-2008, 07:13 AM   #3
atec77
I doubt it needs a reset but I would be shopping that around as the radiator can be had much cheaper and the 2k sounds like a change over not a find the problem and fix it at an affordable
Old 12-04-2008, 08:03 AM   #4
F6 R-Spec
formerly PURSUIT-250
F6 R-Spec's Avatar
I would shop around, in Melbourne i can get you the Auto and rad done WAY under 2K.
Cheers Mick.
F6 R-Spec is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2008, 09:38 AM   #5
TE50 027
Tickford Tough
TE50 027's Avatar
If he's willing to spend a grand on a radiator you can get a PWR aluminium one for $900.
Sparkling Burgundy T1 TE50 Build #027 - SOLD
TE50 027 is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2008, 10:16 AM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
I would shop around, every major city you can get a fully rebuilt trans and radiator replaced for WAY under 2K - just like pursuit-250 said.
Old 12-04-2008, 06:07 PM   #7
rockoz
Cool but what I wanted to know was, if it threw a warning light, would it have stayed until reset?
Thanks for the replies
Old 12-04-2008, 06:09 PM   #8
The Monty
Just slidin'
The Monty's Avatar
It shouldnt have. It will just come up as an error code when checked at a Ford dealer.
Old 12-04-2008, 06:23 PM   #9
rockoz
apparently the guy who fixed it said a warning light should have come on but I didnt see one. btw im getting the blame for blowing up the box, hence my interest
Old 12-04-2008, 06:49 PM   #10
GK
Walking with God
GK's Avatar
If the box was overheating, it should have gone into Limp Home Mode, whereby it stays in third gear.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 12-04-2008, 06:52 PM   #11
F6 R-Spec
F6 R-Spec's Avatar
You will find that NO WARNING light came on, but if you scan it a Fault code will come up sometimes.
It will just store the code, in memory but will not effect anything. if you get a chance to clear it do it, if not don't sweat about it.
There is also the possibility that the code could have been there before this problem occurred, the scan tool wont tell you that.
I was towing a very heavy load (Boat &Trailer) in my dads BA wagon a couple of weeks ago, had no tranny cooler as i had not had a chance to fit one,
i got the auto very HOT to the point where it threw oil out the breather .
We let it cool down for 30 min's and of we went again, all ok.
I serviced it and fitted a tranny cooler to it, checked for codes and NOTHING.
cheers Mick.
Old 12-04-2008, 07:07 PM   #12
rockoz
definitely no limp home mode at any time. only sign of drama was a little slip going into reverse once, but put that down to low fluid. its got over 200k kms on it and only been serviced once.
Old 12-04-2008, 07:16 PM   #13
Chamelion
200k, serviced once!? No wonder it's rooted! Talk about a sad lack of maintenance... How long does he leave it before changing the engine oil? 40,000km? : .. I digress...
Certainly by no means your fault in the slightest... It couldn't be.
Chamelion is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2008, 07:23 PM   #14
rockoz
guess im looking for some way to prove it to him that it wasnt my fault
Old 12-04-2008, 07:32 PM   #15
The Monty
Just slidin'
The Monty's Avatar
It will fail regardless of whos driving if its only ever been serviced once in 200 000 k's. Tell your mate to grow up.
Old 12-04-2008, 08:21 PM   #16
rockoz
Thanks for the info guys. Im from the " other side " and not up to speed on Ford technical things.
Old 12-04-2008, 08:31 PM   #17
GK
Walking with God
GK's Avatar
Sums it all up rather nicely! LOL!
GK
Now gone!
On LPG
Old 12-04-2008, 08:35 PM   #18
GK
Walking with God
GK's Avatar
I'm sorry his auto stuffed up, but goodness, 1 service in 200,000 kays! Think of the state of the fluid, black, burnt and low, filled with lovely bits to grind away at the drums inside!
There's the reason you're looking for.
GK
Now gone!
On LPG
