Old 23-05-2008, 03:32 PM   #1
FC:LTD
Default Removing rear disks au 1 ute
Hi,does any body know the procedure for removing rear disks on an au1 ute.
I have removed the caliper and grub screw but it still seems to be stuck .
The handbrake cable has been disconected .I have removed the grommet and looked inside, is there a way of backing the handbrake off further through this hole ?I think the handbrake shoes have created a ridge does this sound right?
FC:LTD is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2008, 04:08 PM   #2
philstoj
philstoj's Avatar
They would be nice and tight on the handbrake shoes.
Give the rotor a few good smacks with a hammer, it will loosen them up, and then just pull them off by pulling at the rotor from each side.
Old 23-05-2008, 05:50 PM   #3
NC1183
NC1183's Avatar
Would it be a good idea to leave a couple of wheel nuts on while pulling so it does come off in a hurry and hit you?
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2008, 12:22 AM   #4
FC:LTD
I have had a puller on it and it has bent the rotor out of shape ,I have hit it with a hammer at least 50, times that method dosent seem too be working!
what else could be causing this ?
Old 24-05-2008, 10:09 AM   #5
ohzone
Dent Removal
ohzone's Avatar
I wonder if it has rusted around the boss area on the axle and this is stopping it from coming off, perhaps a bit of heat applied to the rotor but keep the axle "boss" cold may help?
P.S don't forget the fuel tank resides near by and there are other ignitable products around also, so be careful with a naked flame
ohzone is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2008, 10:21 AM   #6
philstoj
philstoj's Avatar
It will be rusty around the axle flange and around the studs for sure.
Give it some hammering on the face of the rotor around the studs to loosen it up.
They are a pain but the do come off.
Old 27-05-2008, 11:51 PM   #7
FC:LTD
Thanks for the replies , one side came off easily the other i had to soak with crc for three days . All fixed now
Old 29-05-2008, 11:28 PM   #8
EvilChief
Boost Addict
btw u can unadjust the handbrake through the back ;)
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
