Old 25-06-2008, 09:35 AM   #1
brad`
The Monty
brad`'s Avatar
Default Green wire ?
hey, i had an idea this morning when i woke up a cheap cosmetic idea.
i thought i might change the dash on the fairmont, where the rear demister, areial, c-locking buttons are. To having four buttons with the fairmont badge in between the buttons.
Like this
obiviously thats a Ghia badge but you get the idea behind it.
when i took the black plastic guard away from the buttons i came across an extra wiring loom/connector that is green
i then noticed that there are colour coded
Demister has a white sticker and a white connector
Arial has a Blue Sticker and a blue connector
C-Locking has a Orange sticker and a ornage connector
anyone know what the green is ment to go 2 ? its all wired up just like the others. any help would be greatly apreciated.
also i need a new button weather it be Traction contol or something else, as well as the new black surrond with badge anyone know where i can find 1 ? havnt tried wreckers yeat but im gettting there.
thanks brad`
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2008, 09:51 AM   #2
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
Its for the traction control. The wiring harness is the same in fairmont as fairmont ghia, just you dont have hte switch or that function in the BEM "Turned On" and you dont have the right ABS system under the bonnet. I have the same in my fairmont. Best bet for the switches & new switch surround would be the wreckers (or ford). Sometimes you see them on ebay, but not to often.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2008, 10:12 AM   #3
brad`
The Monty
brad`'s Avatar
i was ashuming it was for traction control. i dont necisarialy wont it working just want it so it lights up when the headlights are on.
i rang all the wreckers around here and i think they thought i was on drugs talking about 4 buttons instead of 3.. crazy talk it is.
thanks mate apriciated
brad`
Old 25-06-2008, 06:09 PM   #4
superroo
You can't stop the signal
superroo's Avatar
Pretty sure i have a T/C button lying around at home which i don't need. Will get back to you once i get there.
Old 25-06-2008, 06:48 PM   #5
brad`
The Monty
brad`'s Avatar
hey would be greatly apreicated, look forward to hearing back from ya.
