Old 22-07-2008, 10:20 PM   #1
Slow Ute
Default fuel filler Au ute
well ive had my new/old AU ute for about 3 mths and the fuel filler is really starting to give me the sh.t's it would have to take at least 5-10mins to fill the thing from empty.
is this a common problem if so is there a way to fix it. i thought my old hilux was bad but this would have to be the worst filler i have ever come across.
2008 Rav4 SX6. V6 auto. 200 killerwasps of goodness :thebirds:
AU3 Ute (work horse) :
AU1 Fairmont Ghia VCT 6 SOLD
2005 toyota hilux V6 auto 14.9 @89mph SOLD :the_finge
starting new project 2007 (probably 2009) sleep:
Slow Ute is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2008, 10:58 PM   #2
b2tf
not here much anymore
b2tf's Avatar
what do you mean? ive never had a problem with it
2024 F150 XLT
Old 22-07-2008, 11:01 PM   #3
aye you
The Origional, The Best
aye you's Avatar
Some servo's have slow pumps too maatee
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2008, 11:38 AM   #4
Slow Ute
Question
nah not the servos. have tried about 8 different ones and still the same issue. basically when u pull the trigger it clicks off straight away. have to fill it real slow. giving me the sh.ts going to pull it out and see.
Old 23-07-2008, 11:55 AM   #5
F6 R-Spec
formerly PURSUIT-250
F6 R-Spec's Avatar
Try not to shove it all the way in, pull it out 15-20 mm, should work a treat.
The fuel bowser im talking about.
Cheers Mick.
F6 R-Spec is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2008, 03:32 PM   #6
poolkeeper
Its Resonating!
poolkeeper's Avatar
Cheers Mick.
2nd
This is what the guy at the servo said to me, he works on the pumps also..
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2008, 04:32 PM   #7
howesy
howesy's Avatar
Mines the same from new. If you put it in all the way she protests but pull it back out around an inch or a bit more and she's no worries and you can squeeze her as hard as you like then but with it in all the way it clicks off within seconds.
Can't beat a Windsor for sound and low down torque.
Liquid Silver Pursuit250
Custom gear and diff ratios
ECU
Exhaust
Crow Comp. Valve springs
Adjust. Rollers
Cold air
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2008, 07:49 PM   #8
Slow Ute
none of those things work. have tried everything im starting to think there might be a blockage in the filler. i have pulled it just about all the way out and it still does it. do the falcoons have a anti syphoon thing in it cause im thinking that might be the problem. really really gives me the shits.
Old 23-07-2008, 08:02 PM   #9
BIGJB
BIGJB's Avatar
I would pull the filler out and look. If you have tried all that people are saying it makes me wonder if it had a locking fuel cap and someone lost the keys and smashed the lock but in the process dropped half of it down the filler tube and therefore blocked the tube some wat.
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2008, 08:02 PM   #10
bodes-sh
could be a blockage in the breather pipe. if it's crushed or blocked it won't vent the vapour and air back out of the tank as you are filling, therefore forcing it back up the filler neck and cutting the trigger out...does it make any difference if you rotate it 90º?
Old 23-07-2008, 08:30 PM   #11
Slow Ute
90deg dont do anything either, have even tried it upside down. did the utes have lockable filler caps from factory. the one on the ute is plastic and dont lock.
Old 23-07-2008, 08:55 PM   #12
BIGJB
BIGJB's Avatar
Don't think they came out factory. The lockable 1's are plastic as well. We get em at work all the time with no keys. We don't bust em but, we pic em.
Old 24-07-2008, 08:36 AM   #13
all4fordau
What happens is that the entry flap on the filler breaks off and gets stuck in the filler pipe. Have a look inside your filler right where the pump nossle enters. In here you should see and flap that pushes back as you insert the nossle. If it is not there chances are that it has broken off and got stuck inside the filler pipe, causing restriction when trying to add petrol. I had this same problem. Straighten a coat hanger and put a small hook in one end. Then it is time to go fishing! You should be able to hook the damaged flap back to the top and then pull it out with a pair of long nose pliars. Good Luck!!!
all4fordau is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2008, 07:34 AM   #14
Slow Ute
you sir are a legend. went and had a look with the torch last night and sure enough its gone and the little flap is inside the filler. now i just have to work out how to get the mongrel out.
Old 30-07-2008, 10:36 PM   #15
all4fordau
How did you get on getting the flap out???
