24-07-2008, 08:18 PM | #1 | ||
OK guys,audio related but an AU question so I'll post here,has any one fitted 6" round speakers in the front doors of an AU with out any major mods and as well as has any one fitted 6x9s in the lower section of the rear doors(wagon),My car being a wagon I also want to fit 5" in the rear speaker locations where the factory 4" item go as well
I didnt want to be the guinea pig on this,so I thought Id ask you guys first Regards Dave
T2 TE50 no:154 Narooma blue AU2 XR8 ute XR4 fiesta |
24-07-2008, 08:50 PM | #2 | ||
All Bran = Regular Member
I'd previously fitted 6.5" Hertz and now I've got 6.5" Alpine Type X's.
The Hertz's were more difficult to fit because of the mounting depth (I wanted to retain the factory door grills). If you're going to install decent speakers you'll need to make/buy some spacers. I made mine from mdf It's easy enough to mount 6" or 6.5" but just make sure of your mounting depth. Pic of Hertz edit: Oh, I fade my rears out. I don't sit in the back seat so don't need them Last edited by ronwest; 24-07-2008 at 09:08 PM. |
24-07-2008, 08:59 PM | #3 | ||
not here much anymore
I've got a set of 6.5" splits for the doors (ute so no back) to go in but I do need a spacer, just havent made them yet.
2024 F150 XLT
24-07-2008, 10:10 PM | #4 | ||
CYCO4D Wagon.
I bought 6" speakers, I havent installed them, but got told that 6" will fit without having to change anything. So yeh being a wagon, I am abit lazy to change them really. I should actually get onto it. I was shattered that I couldnt fit no 6 X 9's in there :(
www.aufalcon.com.au/cyco4d |
25-07-2008, 11:19 AM | #5 | |||
THE Fairmont Ghia 75th
cheers
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install. My Ride My Build Thread |
25-07-2008, 12:19 PM | #6 | |||
Check the mounting depth of the speakers as that will determine how you need to go about it. The Hertz in the pic were done that way as there was less than 1mm clearance to the window and about the same to the stocko door grills. It may be that you won't need to rout the insides but no, it wasn't difficult with the right gear - I still have all my fingers |
25-07-2008, 04:22 PM | #7 | ||
lol, yer for sure, cool as, ill go get some to do it now, that'll be for another weekend, tryna get the sub box done first, just finished the false floor apart from cutting the top for the perspex above where the amp will sit...
25-07-2008, 07:30 PM | #8 | ||
ok guys thanks for that,any one fitted 6x9s in the reaer doors and 5" in the wagon speaker compartment?
25-07-2008, 07:58 PM | #9 | ||
matey i wouldnt bother with 6x9s to start with...
and they will ruin your audio staging in the rear doors being that close to your head which is closer than the front speakers(sound comes from infront of you not behind ... thats why you face a band ;) ) the spacers are only as thick as they need to be mine are 10mm .. i have 6.5" focal splits (to mount round speakers properly you need to make a spacer to fill in the gap around the speaker so it sounds right) good luck mate
25-07-2008, 08:31 PM | #10 | ||
OK,If I can get 6.5" in the front doors,I can make spacers no worries,I just didnt want to hit the window or have the cut the door in any way and use the factory door grill,And then fit 5" in the rear I would be happy....... for now
25-07-2008, 08:37 PM | #11 | ||
i had to trim some of the surround of the grill (but you cant see the bit i trimmed)
27-07-2008, 04:27 PM | #12 | ||
Teh Baest
Mate, bugger the 6x9's!
Get a good set of 6.5" components for the front stage, run them off a decent amp and the sound will be fantastic! I have 6.5" MB Quarts running off a RF Power T400-4 and it sounds fantastic!! But, yeah as everyone has said, you will need to make up some spacers to make it fit and sound right. Everybody i was talking to in the audio scene said bugger the rear stage.. Unless passengers are often in the back, it is really of no use. Especially if you have some huuuuuuuuge subs The vibration from the subs can actually interfere with the coils in the rear fill apparently?
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ) |
27-07-2008, 04:45 PM | #13 | ||
yeah well if you watch the rear lil speakers when not connected.. the air moved by the subs pushes them as tho they are working but they arnt... i know that can NOT be good for them haha!!
28-07-2008, 01:38 AM | #14 | ||
Just to note, the rear speakers in my wagon (and all to my knowledge) are 5.25" stock, not 4". I bought some aftermarket 4's which were too small, though I put them in anyway with some dodgy spacers.. Not that they're audible with my perspex cargo barrier in place!
28-07-2008, 05:24 AM | #15 | |||
www.TUFFCARPARTS.com
Ah well, serves me right for not checking! Plus I can chuck in my MB splits instead (mids only).
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
29-07-2008, 12:09 AM | #16 | |||
I did go rear-fill in my ute though ... as sometimes i don't crank the bass up that much ... I just put 5x7 Pioneers in ... and hooked them up my Pioneer 4-ch. I run 6" splits in the front doors with MDF spacers to hold my tweeters in next to them behind the factory grille. I fade it mostly to the front anyway and just allow a low amount of fill from behind. Sounds the goods ... although my HPF on front channels of my Pioneer 4-ch has died .... so i think it will be cheaper just to get another amp (have had that Pioneer amp for 5-6 years ... so has served me well).
29-07-2008, 05:26 PM | #17 | ||
Quick question for those who have done it, whats the maximum depth you can mount a 6" speaker into the front doors without them hitting the windows?
2024 F150 XLT
29-07-2008, 05:51 PM | #18 | |||
From memory (I'll check later) I had to rebate the adapters to 6mm depth. Soooo, 67mm - 6mm = 61mm (between door inner skin and window - allowing a cigarette papers clearance). I'm working tonight so I'll confirm all that later but it won't be far out. |
29-07-2008, 07:15 PM | #19 | ||
Ok, to confirm the measurements:-
Door inner skin to window = 61mm Door inner skin to stock speaker grill = 13mm Therefore front speakers cannot be anymore than 74mm overall (if stock grills are used). (My Hertz's were 72mm total depth but by the time I put some bitumastic sealant between the speaker and the rebate, and, the adapter and the door skin it ended up "just" fitting). As a by the by, both my Hertz and Type X's tweeters "just" fitted in the factory A-Pillar position. |
29-07-2008, 07:43 PM | #20 | ||
Hold on ... if the inner door skin to the window is 61mm ... that means the speaker is mounted 13mm back from the inner door skin ... that means from the front of the speak to the window there is actually only 48mm ... if my Maths are correct.
Going on the above figures ... unless the above figures are incorrect.
29-07-2008, 08:27 PM | #21 | ||
doesnt look good for my RF splits then, looks like I'll have to make up some sort of grille. They're fairly deep.
2024 F150 XLT
29-07-2008, 08:30 PM | #22 | ||
i think it was bluedriver? had the grill cutout directly infront of where the speaker was
and there was another AU that had pods made that fitted where the stock grill is then wrapped under the handle part to make it sort of flow.. ill upload a pic
29-07-2008, 08:39 PM | #23 | ||
29-07-2008, 08:42 PM | #24 | ||
those look good, my rockfords have a grille which id put over them if they end up sticking out. Im thinking if I use the stock grilles, glue some MDF to the back of them then cut through them to fit the speaker that will work ok. The only thing I cant work out is, if I do that, how can I mount the speaker to the actual door just to give it a bit of strength?
2024 F150 XLT
29-07-2008, 08:44 PM | #25 | ||
if you made a REALLY REALLY thick spacer(or used steel(seen it done on audio sites)
you could screw the mdf your talking about to that and the speaker thru that to the big fat mounts etc... OR remove the grill(they just clip out once you remove the single screw holding them on) and make the required mods to make it fit behind them.
29-07-2008, 08:47 PM | #26 | ||
i wonder if i could modify the speaker grille so it is a seperate part to the doortrim (ie not connected at all), so that way if i need to take the trim off i can?
2024 F150 XLT
29-07-2008, 08:53 PM | #27 | ||
if you filed off the clip tangs you could definatly do that..
as the grill clips on the edge that you can see (going away from the camera) pull off a trim and have a look.. its quite obvious and would be easy i think with some mdf and fibreglass
29-07-2008, 08:55 PM | #28 | ||
yeah ive had it off before, i reckon that would be the way to go. make an MDF spacer, mount the speaker in it, attach to door, then put the speaker grille over the top and get it to the right height.
2024 F150 XLT
29-07-2008, 08:55 PM | #29 | |||
29-07-2008, 09:23 PM | #30 | ||
Ok, had my coffee
Because my spacers are rebated, the Hertz's mounting surface sat 6mm into the grill -> inner skin space. Given that the mounting depth of the Hertz's is 67mm, the calculation has to be 67mm - 6mm = 61mm (inner skin to window depth). The 13mm distance between the grill and the inner skin won't change so it still comes out at 61 + 13 = 74mm (grill -> window) Last edited by ronwest; 29-07-2008 at 09:33 PM. |
