Old 25-07-2008, 02:46 PM   #1
GT88
BA Mk2 Fairmont
Default Side mirror shakes
The drivers side mirror seems to be shaking a bit while the car is idle and also while driving. It gets rather annoying especially when driving down the freeway. How do I go about tightening the mirror so it doesn't shake?
GT88 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2008, 03:40 PM   #2
blackers10
blackers10's Avatar
from memory its a spring inside the mirror housing that holds the mirror still(because of how its mounted to allow it to move with electric motor etc)
this spring tires and stretches and becomes useless...
they dont stay tight for all that long either sadly..
just pull the mirror apart and you will find it
Old 25-07-2008, 03:58 PM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
do you mean just the mirror or the whole encasing?
one time my mirror was shaking lots at idle. Just gave it a push around with my hand, problem solved.
Old 26-07-2008, 02:55 PM   #4
GT88
BA Mk2 Fairmont
The actual mirror moves. If it is the spring, where do I get a new one from? SuperCheap?
Old 26-07-2008, 04:30 PM   #5
falconboy
Hi blackers10, If its the spring I'm thinking (theres 2, top and bottom of it), you can't access the damn thing in the mirror casing can you and need to replace the whole mirror unit? Unless theres some way of getting in there that I can't figure out. I wanted to fix one, the spring is attached to a metal piece that looks like its just glued into a slot, and it has pulled out of the door side section, leaving the mirror flopping. Taking the mirror off and taking all the back off, although I can see it all and how it works, l can't access it.....
Edit: Sorry, I'm thinking of dads ED which I'm having trouble with. Maybe the AU's can be fixed.
falconboy is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2008, 04:33 PM   #6
HLC
Audi S3
mine shakes too. so annoying. i figured a new unit would just fix it. but i dont wanna spend that sort of money.
Old 26-07-2008, 06:43 PM   #7
GK
Walking with God
GK's Avatar
I've had that sort of realisation a few times now. I'd love to fix something so it's absolutely shmick, but the cost makes many things unjustifiable. LOL!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 28-07-2008, 05:58 AM   #8
au2sw
Blown 5L coming
au2sw's Avatar
heres a thread that i put some pics in. i believe that most falcon mirrors are the same in regards to the set up. correct me if im wrong though.
http://www.fordforums.com.au/showthread.php?t=11227737
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2008, 12:01 AM   #9
Mechan1k
Mechan1k's Avatar
Mine does it ... even after getting the entire mirror housing replaced ... so I am going to do a bit of modifying.
I am going to get some thick foam off-cuts ... and I am going to stuff it in behind the mirror to stop the wobbling/vibration. Will see how that goes.
Old 29-07-2008, 08:19 AM   #10
HLC
Audi S3
thats a good idea!!!! just use the old expanda foam though :
Old 29-07-2008, 07:14 PM   #11
Mechan1k
Mechan1k's Avatar
I was thinking that ... but if you need to adjust it ... with the "space-invader" foam it won't allow mirror adjustment (well that's just my thoughts ... hee hee).
Old 29-07-2008, 10:14 PM   #12
bloggs24
cant be as annoying as this damn spider that lives in my mirror, theres a fresh web coming from my mirror every morning!!
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
