15-08-2008, 10:02 AM | #1 | ||
Sales Representative
Can someone explain what ESS and Tiptronic are? and is Tiptronic the one with the steering wheel buttons? I have a plan with a shiftkit and override system, but need further details of these as to what they do, how they work etc. Can anyone help?
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
15-08-2008, 10:07 AM | #2 | ||
TICKFORD XR6
isnt tiptronic the system thye have on BA's where u are able to change gear like an manual ( to a point)
dimi
The Ride:Ford EF XR6 S1 Plans: Slam it on its ***, Sports exhaust( upgrade), Rims, Cam, CAI, Extractors +...
The Drive Line: 4.0L MPI 4speed Auto TICKFORD ENHANCED How she Rides: 15inch XR6 MAGS Sound system:JVC head unit with AUX... 6 Inch in doors,rear with a Vnet 15inch & Infinity 12inch Subs In the Boot Running of a Coustic amp The Mods: Pod Filter, exhaust...... |
15-08-2008, 10:13 AM | #3 | |||
15-08-2008, 10:23 AM | #4 | ||
Wizard Member
Tiptronic is the BA type manual shift auto, as to ESS have no idea...
Frosty and FPR - Bathurst winners 2013 |
15-08-2008, 10:28 AM | #5 | |||
15-08-2008, 10:29 AM | #6 | ||
AWD Assassin
ESS - ( Electronic Sports Shift (ESS) ) is best known as the steering wheel shift buttons ( Tickford T series )
Allows you to shift up or shift down by using the buttons on the steering wheel - Not quite shift paddles, but you get the idea. ( you do not use the shifter to change gears ) Tiptronic is what you see in the BA - BF auto shifters. You push the Auto Shift lever over to Performance mode and then you tap the T Bar shifter up or down to change gears. |
15-08-2008, 10:33 AM | #7 | ||
electrically there is no difference between the 2 they just use a different method to change gears the shifter or steering wheel buttons
[SIGPIC][/SIGPIC]
15-08-2008, 10:39 AM | #8 | ||
So the ESS gives it a full manual over-ride? or a partial like the std auto boxes?
15-08-2008, 11:01 AM | #9 | |||
AWD Assassin
15-08-2008, 11:18 AM | #10 | |||
So the next question lies with using the ESS with a shift kit... what i wanted is to have an adjustable se so the ESS is more "obeyable" with a firmer setting from the shift kit.
15-08-2008, 02:38 PM | #11 | ||
Another question... Can i have both Adaptive shift and ESS at the same time? or just stick with the initial thought of ESS with a custom shift kit?
15-08-2008, 02:56 PM | #12 | |||
I miss my wheelbarrow
BTW, ESS stage 1 in the T1's had no safeguards, the T1 TE50 I drove in 1999 would hold first to the limiter, but my T2 TE50 that I bought would upshift at around 5800 when held in "1" in ESS, that was with a ~ 6200 limiter Daniel |
15-08-2008, 03:28 PM | #13 | ||
Ah... Cat600... so if i just go for the ESS conversion, i'll have adaptive shift anyway ... now... anyone got any documents and such on how to do it?
15-08-2008, 06:33 PM | #14 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
15-08-2008, 08:13 PM | #15 | ||
Jump on the T-series forum and have a chat to someone with a ees auto set up.
From what ive heard EES absolutely kicks *** hey ford discontinued it cause when it goes wrong its pretty expensive to fix? But the idea is essentially a tip tronic style on the steering wheel- either side of the wheel has up and down shifts kinda like a sony ps2 controller up and down directionals/ or a kinda light switch. If i was buying a T3 id get ees as the windey roads or just round abouts would be fantastic! |
15-08-2008, 08:34 PM | #16 | ||
Barra Turbo > V8
ESS isnt as good as most people make it out to be, on a track it can be quite confusing with the steering wheel location. I barely ever use mine, except when im chasing Peuty over the mountains to somerset :
15-08-2008, 08:35 PM | #17 | ||
the only problem with normal au boxes it they won't hold 1st electronically, it will drop itself into neutral at about 60km/h, this is because of the solenoid setup in them. apparently all e series 4sp autos will hold 1st, as will ba's obviously. just something to consider...oh btw, it's not as easy as just slapping a control unit together to do it. it does take a lot of configuring
15-08-2008, 09:33 PM | #18 | |||
Interesting point about the AU box though... makes you wonder if a custom shift kit could help hold it...
16-08-2008, 12:18 PM | #19 | ||||
You can't stop the signal
A long time ago, before you were around, JC played around with this setup, and tried to get a BA shifter working in an AU, on the cheap. Thats when he found the solenoid issue. And at $500 or so for the solenoid, it wasn't the cheap he was looking for. Cheers
16-08-2008, 01:19 PM | #20 | ||
Wizard Member
I don't understand this AU won't hold first gear, I use my auto like a manual nearly all the time I drive (for the last 5.5 years and the box is still going) and I can hold mine to the limiter in first which now its been tuned is around the 6k mark and about 65 - 70 kph speed mark. So can someone please explain what they mean?
16-08-2008, 04:04 PM | #21 | ||||
... Fear it!
Here, Here! I barley use it, only really on high way driving ... but try and over take whilst she is in 5th n she will barely move :( :(
Chrysler 300C Sedan
SY Territory Ghia |
16-08-2008, 04:14 PM | #22 | |||
Barra Turbo > V8
IMO highway driving is where i use it the least, if im having a punt somewhere on a twisty road i might use it but vary rarely
16-08-2008, 04:23 PM | #23 | |||
I went to drop it back to 2nd the other night and accidentally went back to 1st doin a lot more speed than was favourable. What got me was the fact that it went back into 1st. Thought it would have not allowed it to go back if it was goin to possibly damage anything. |
16-08-2008, 04:35 PM | #24 | ||||
... Fear it!
Chrysler 300C Sedan
SY Territory Ghia |
16-08-2008, 04:41 PM | #25 | |||
as for the op, it requires 2 seperate controllers, because, as muzza has discovered in trying to develop the first one, the shifting from the steering wheel has "noise" in the ground circuit, so it doesn't work properly.... you are best off pming him for more info |
17-08-2008, 06:03 PM | #26 | |||
Audi S3
FOUR SPEED AUTOMATIC
17-08-2008, 06:27 PM | #27 | |||
17-08-2008, 06:59 PM | #28 | ||||
... Fear it!
you know what i mean, (or you prob don't : ) but when you put it into ESS mode you can go up to 5!!!!! i aint no mechanic, just do what the car tells me :evil3:
Chrysler 300C Sedan
SY Territory Ghia |
17-08-2008, 08:25 PM | #29 | ||
XR 67 IS HEAVEN
ok here we go.I own a T1TS50 when in ess the ts will go up and down as soon as i press the button it doesnt have a safe gaurd trust me i have bounced the limiter, also 5th is a tourqe lock it is still a 4 speed ,and adding to that with the ts if you select 1st with ignition off then turn the ignition on ,wait for the airbag light to turn off then select reverse wait 2 seconds the dash will say PEF for maximum performance.same process but with second gear selects ADP for adaptive, and again third gear selects maximum econamy.where as BA and BF triptronic is a manel way of using the auto as no doubt everyone has done with there standard falccons at some stage . Hope this can make everything clearer cheers...kenny g... :
17-08-2008, 08:36 PM | #30 | |||
Afterburner + skids =
