Old 07-09-2008, 11:00 PM   #1
fordman_01
DUB
Exclamation door won't close??????
hey all, my mates au2 sedan's rear right hand side passenger door will not close. as you shut it it will just hit the lock and bounce back. from the inside when you pull the latch it will stay pulled and not spring back to its normal position unless you do it urself. i am thinking that the cable or something has come off or snapped?
i will pull the panel off tomorrow and see if that the problem.
any help would be sweet.
thanks neil.
fordman_01 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2008, 12:32 AM   #2
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
Yeah they do that, just spray some crc down the cable and on the lock etc. just gummed up, you should be able to manually pull the lock back and fourth to work it thru.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2008, 02:33 AM   #3
blueoval
Critical Thinker
blueoval's Avatar
Yes this can happen sometimes. It sounds like its in the closed/lock position on the door. Just look at the latch part on the door and physically move the mechanism back and forth and spray some wd40 or crc as mentioned. Make sure the latch is in the open position when finished.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2008, 07:35 AM   #4
Mechan1k
Mechan1k's Avatar
And sometimes the entire lock mechanism can fail ... and it's a complete replace job (it's the same as replacing an actuator really.)
Check the cables/rods and if it is connected first though.
Old 08-09-2008, 07:47 AM   #5
fordman_01
DUB
ok thanks for the help so far. i will check the cables first. but yeh i think it is the cable that has come off/snapped cos when you pull the latch from the inside thats the only thing that moves, the lock does'nt move or anything just the latch.
Old 08-09-2008, 09:41 PM   #6
fordman_01
DUB
thanks for ur help everyone. i have fixed the door the cable thing had come out of its socket.
Old 08-09-2008, 10:18 PM   #7
HLC
Audi S3
my drivers door does this, but as soon as i pull the handle on the outside, it will close first go next time.
so you guys reckon spraying some slippery stuff inthe mechanism?
Old 03-11-2008, 08:47 AM   #8
low au classic
EA FALCONED
low au classic's Avatar
i have a simalar prob but the drivers door wont shut have to slam it and u can hear the latch hitting around inside
low au classic is offline   Reply With Quote Multi-Quote with this Post
