16-09-2008, 05:45 PM | #1 | ||
Hi all. My partner has an AU fairmont and we are about to go on a trip. Now as silly as this sounds, I cannot find the dipstick for the auto trans fluid?????? Can anyone help with the location of this or am I just going mad????? (Be Nice!)
Cheers, Jason |
16-09-2008, 06:05 PM | #2 | ||
V8 Powaah
There isnt one. You arent mad, they removed the dipstick after the EF, because of idiots pouring dextron 3 down it instead of TQF95.
If you keep the transmission serviced and its operating well, well it should be just fine. Ford say that it is a sealed unit now, but if you have any serious dobuts you might want to get the transmission serviced it isnt very dear.
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
16-09-2008, 06:07 PM | #3 | ||
Au's don't have a dipstick to check tranny oil level they are checked by a plug on the side of the box like a manual.
16-09-2008, 06:11 PM | #4 | ||
Yep no dip stick. 16mm plug on drivers side of gearbox, check level when car running and in park. Some transmission shops drill and fit dipstick for the lazy.
16-09-2008, 06:38 PM | #5 | ||
how often should the auto fluid get changed? my 2002 coon is up to 170k and i don't know that it has been changed (not by me in 3 years and nearly 100k anyway)
16-09-2008, 06:43 PM | #6 | ||
when i got my full flush and service, the mechanic told me it would be good for another 50k, the car is on 147k and while everything was running fine, from the looks of the oil, it had never been done before. my full service cost 200 neat, and id recomend you get it done to be on the safe side.
16-09-2008, 07:40 PM | #7 | ||
not here much anymore
There is one, its on the side of the gearbox so you'll have to jack up the car and get right underneath the gearbox, keep looking till you find it.
2024 F150 XLT
16-09-2008, 09:45 PM | #8 | ||
Used to service the auto every 30-40,000km ... a lot cheaper than a replacement/rebuild. I had to get a rebuilt one anyway as the previous owner never serviced it. After the rebuild went it .. i was religiously serviced (even though it got worked hard and carried a lot of load) ... was still like new 130,000km later on the rebuild (mind you I had strengthened internals put in it).
I advise notdoing more than 50,000km between auto services ... preferrably less actually.
17-09-2008, 07:19 AM | #9 | ||
the 'auto service' that everyone is talking about, is that just change the auto trans fluid? or something more indepth?
17-09-2008, 07:38 AM | #10 | |||
gone fishing
Cheers Whiskers |
17-09-2008, 10:09 AM | #11 | ||
AU Club Mod
not sure when my gearbox was last serviced... but its whining in D on take off and when i take my foot off the accelerator...
17-09-2008, 12:58 PM | #12 | ||
I would suggest if it is starting to whine take it in to shop and get a power flush done as well as a service. By doing that they will change out all the trans fluid.
17-09-2008, 01:44 PM | #13 | ||
AU Club Mod
sweet cheers mate.
Any idea on how much that should cost?
17-09-2008, 02:05 PM | #14 | ||
Critical Thinker
i get a whine in 1st gear also. was told by transmission place that planetary gearing is starting to wear. common problem in au's apparently.
i do trans service every 25,000km. just out of habit. overkill i know. :P
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
17-09-2008, 02:08 PM | #15 | |||
AU Club Mod
17-09-2008, 02:12 PM | #16 | |||
Critical Thinker
replace it when it gets too noisey to bear.
17-09-2008, 02:37 PM | #17 | ||
AU Club Mod
well its fairly noisey as it is now... but i took it to the transmission place that ford contract to look after there diff's and gearbox's and the guy said it was a common problem in the gearbox..
But didnt think it needed fixing straight away as it was first thought that it was a diff problem but was then dignoised as a gearbox problem. Its fairly noisey now.. and sometimes it can have a slight pause before it goes into gear... But i dont think ford will honor it.. as it was hard enough to try tell them there was a problem to begin with... they first said it was my exhaust :togo:
17-09-2008, 04:01 PM | #18 | |||
Critical Thinker
17-09-2008, 04:40 PM | #19 | ||
AU Club Mod
Do you think what Foggy sugguested could stop the whine in the gearbox? Ino it may not last for ever.. but i will look at getting it rebuilt in the not to distant future
17-09-2008, 05:07 PM | #20 | |||
Critical Thinker
18-09-2008, 10:06 AM | #21 | ||
Nice thread, plenty of useful information, I have a question if those who are knowledgeable to answer, I had taken my 02 AU 6Cly Auto Falcon to my mechanic Tuesday, as I am travelling out of town this weekend short notice, and I haven't the time to conduct the work myself, but I had him do a seal kit and change the transmission oil, as well as the diff oil based on his recommendation that it smelt burnt. Also he replaced the extensions housing seal as per my request, now when I drive, its an intermittent fault, changing from second to third, the engine revs up like a blip, and takes a half a second to change into 3rd, its not a big issue, but prior to having a service it never did this before, I mean ever. Any ideas?
18-09-2008, 03:38 PM | #22 | |||
I had something similar happen of late and it wasn't good news for me - ended up getting a reconditioned box put in. It upset me quite a bit to spend $500 being a good kid getting a service done (full flush + a seal or two) to find that when i got it back it was a complete dog with similar symptoms to yours (over rev and delay on gear change). The final diagnosis was worn clutch plates and my guessnosis was that playing around with the bits inside the transmission ruined the state of equilibrium that had existed with all the original bits dying together in harmony. |
18-09-2008, 09:07 PM | #23 | ||
A four letter word comes to mind, okay, the car should be okay for a little while you reckon? It still works fine, just second to third I can afford to spend the money on getting something done, but tommorow is Friday, and I am leaving Sat'd
