Old 30-10-2008, 08:14 PM   #1
MGM
MGM's Avatar
Default vibration? kind of
I have noticed a small vibration that seem to be getting worse, barely noticeable sometimes, its like driving over very small lumps in the road, i thought it was the road but it does it on the new part of eastlink to, the steering wheel sometimes shakes a little bit but not much. can worn shocks cause this?
BTW its an AU3 xr6 ute
MGM is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2008, 08:27 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
yes. as can tyres, as can wheels, as can alignment, as can wheel balance, as can about a dozen other things.
Old 30-10-2008, 09:05 PM   #3
orsm8
orsm8's Avatar
Lower balljoints could be shot. sometimes if you hit a bump it can feel like the wheel is wobbling and then it settles down untill the next big bump. So check the lower balljoints?
orsm8 is online now   Reply With Quote Multi-Quote with this Post
Old 30-10-2008, 09:36 PM   #4
mik
mik's Avatar
loose inner /tie rod ends or slop in steering can also give intermittent wheel wobble.
Old 30-10-2008, 09:47 PM   #5
MGM
MGM's Avatar
i put the front wheels on the back a while ago and 2 months later the left one ended up like this:
it was the same on the opposite side to what this is, not all around the tire
Old 30-10-2008, 11:22 PM   #6
Mr Hardware
sounds like you've got a real problem somewhere or really crappy tyres or both...
Old 30-10-2008, 11:43 PM   #7
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
Looks to me like you need a wheel allignment.Have you lowered it and not put a camber kit in it by any chance??
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2008, 08:43 PM   #8
mik
mik's Avatar
i rang pedders a few weeks ago about a front end check, they will check for mechanical problems, shockers, alignment for about 30 buks i think, it might be worth a visit.
Old 31-10-2008, 09:09 PM   #9
burnz
VFII SS UTE
burnz's Avatar
it could allso be that section of road, and "not" your car.
GO SOUTHS
Old 10-11-2008, 06:56 PM   #10
MGM
MGM's Avatar
thanks guys, i had a wheel alignment done, the guy found that my nankang tire is seperating the layers, which one of the other tires did of the same brand. when i took the wheel off i rolled it along the flat ground and it would fall to one side, its also made the car axle tramp to, since i took it off i havnt had any problems, except he
told me my caster bushes need replacing :( does anyone know why the tire would seperate? still has plenty of tread left, kind of a waste really
blackauxr8, should i have a camber kit? it has been lowered 35mm in the front and 50mm at the rear from XR height
