Old 13-11-2008, 09:54 PM   #1
TE50 027
Tickford Tough
TE50 027's Avatar
Default Fitting stereo control
The auto T1 TE50 didn't come standard with the steering wheel controls for the stereo. If I can source a controller with all of the cables, is it possible to connect it up or is there something else I need to get it to work? Also, is there a difference between the S1 and S2/3 controller or is it the same with just the head units being different?
Sparkling Burgundy T1 TE50 Build #027 - SOLD
TE50 027 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2008, 01:04 AM   #2
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
The problem is the T series had the gear shift button's on the steering wheel, which use the same connection wiper's on the steering wheel as what the radio button's use on a normal fairmont etc. So you'll need to work out some way of connecting the wires thru that won't tangle when turning the steering wheel, or just disconnect the auto buttons, if its a manual then i don't think they used the buttons for anything, so should be all good?
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2008, 11:41 AM   #3
TE50 027
Tickford Tough
TE50 027's Avatar
Advice from Ford is that it's physically impossible to run the stereo controls and ESS wiring, and I use my ESS too much to disconnect it. Looks like it's back to good old fashion controlling the stereo from the stereo itself.
