Old 14-01-2009, 05:06 PM   #1
Juzman
Default 20" Advanti with Accelera tyres, $2030.. good deal?
Hi guys, someone offered me brand new:
20" Advanti Vivid wheels (http://www.yhi.co.nz/newsite/media/t...08f6de0bd3.jpg)
with
ACCELERA PH1 225/35X20 93W SILICA COMPOUND TYRES
for $2030 delivered. He reckons the Accelera tyres are made in the same place as Continental tyres and are no different...
its a lot of money and haven't heard much about Accelera or Advanti...so thought I'd check with you guys on the deal and the tyres... he also said there will be no scrubbing with those dimensions (and has fitted heaps of 20" on AU-BFs before)
thanks for your help
Juzman is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2009, 06:09 PM   #2
eXi7w0unD
eXi7w0unD's Avatar
grab em dude, thats like 500 for rims and tread for each wheel. i spend like 700 for my 20' rims n tread. lol. just remembers when the tread runs out, itll be 300 a tread for good new 1s
no scrubbing unless u lower it real low.
i won.
eXi7w0unD is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2009, 06:45 PM   #3
Juzman
ahh cool... how many kms you normally get from a 20" tyre?
and will any place fit/balance them (I assume they're not illegal?)
Old 14-01-2009, 06:47 PM   #4
ebxr82nv
Are the wheels 20x8 or 20x8.5? If they're 8.5's go for a 245 cross section tyre. The 225 will scrub the tread on the outside pretty quick. I run 245/40 nankangs on my 20's and haven't had a problem. It's about 40mm lower than a stndard forte
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2009, 12:42 AM   #5
Juzman
yeah they're 20x8.5... he says I can go wider but will cost a lot more...
what are the pros/cons of going wider... worth the extra cash?
Old 15-01-2009, 10:54 AM   #6
ebxr82nv
I paid $2500 for mine. With all tyres they have a tread wear number and it indicates how hard the compound is. A set of 16s that I've got have a 160 rating and they've done just on 40000km on the back. My nankangs have a 320 rating so that means they're harder but being 20s they'll probly wear quicker. I'm expecting upto 50000km from them.
And wider tyres look better to.
Old 15-01-2009, 12:57 PM   #7
Juzman
the guy said I can get 245s for an extra $80... so I might do it... with standard suspension will they rub? Anyone got 20/245s?
Old 15-01-2009, 01:46 PM   #8
Dauphin
Irregular member
Dauphin's Avatar
I have Advantis and they didn't come with hub adapters, to match the Ford AU hub exactly. It led to balance issues (vibrating steering wheel) with outthem, so make sure it will fit the small hub center to "fit on" properly or get the hub adapter things.
Old 15-01-2009, 03:20 PM   #9
ebxr82nv
Ask for hub locators they will either be plastic or alloy. Most aftermarket wheels use them. You wonthave a problem with standard suspension mines lower tthan xr spec and I don't scrub. Iam very careful with drive ways and similar but.
Old 15-01-2009, 03:27 PM   #10
ch33z1l
Dawn
ch33z1l's Avatar
Might be an idea to get longer wheel nuts as with those advanti rims...the lock nut is near impossible to get off with the lock nut tool without burring the thread if they use the rattle gun.
Cost me $80 for the longer nuts.
ch33z1l is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2009, 03:41 PM   #11
ebxr82nv
Tell them you will cut their nuts off if they use a rattle gun. Lazy kents them boys at the tyre service.
Old 15-01-2009, 03:45 PM   #12
HLC
Audi S3
wow. :|
i get like 20k out of a set of tyres. and they arent scrubbing out or anything... :S
Old 15-01-2009, 03:53 PM   #13
ebxr82nv
Mine have already done 15 and still look brand new. Maybe you should talk to your wheel alinment guy.
Old 15-01-2009, 03:55 PM   #14
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
wow, you guys are all about performance, lets see how you go performance wise in the shopping centre carpark. go over a speed bump at half a kay an hour and watch the licourice around your wheel compress so much it dents it.
i have the highest performance wheel and tyre combo, factory 16" alloys! I can drive over anything and hardly feel it! and still get 60thou out of a set.
Old 15-01-2009, 05:18 PM   #15
Juzman
thanks a lot for the info guys, am close to saying yes... but then I read about the 2" rule and my tyre placard says R17, meaning legally I can only go a maximum of 19"?
so does that mean everyone with 20s are driving illegal cars?
Damn... that is annoying, the mag type I want are only available in 20" >:E
Old 15-01-2009, 05:47 PM   #16
HLC
Audi S3
alignment is dead on. same guy does my mums car and she'll get 40+ thou out of a set.
must be my driving.... :hihi:
Old 15-01-2009, 05:48 PM   #17
HLC
Audi S3
well there were AU's released with 18's as standard. t-series cars, xr8 rebels i think had 18's?
so technically yes 20's are legal, but if your placard says 17????
you could always go get a BA placard and stick it over the top
*DISCLAIMER* BUT THAT IS ALSO ILLEGAL AND I WOULD ADVISE AGAINST DOING THAT
Old 15-01-2009, 05:56 PM   #18
Juzman
Mine is an AUII Futura, Sep2000...
lol... tempting... do cops really pull you up over an inch here and there? I guess if you get a bastard... and insurance purposes I guess is iffy also?
I could get a fine black marker and turn a 17 into an artistic 18! :P
Old 15-01-2009, 09:52 PM   #19
ebxr82nv
At the end of the day the cops usualy leave you alone unless you drive like a dick.
My cars DC red, full series 1 tickford body kit with the bi plane spoiler and my 20s are gold with a chrome lip and I've never had any more than a random breath test.
Old 16-01-2009, 12:09 AM   #20
mattp
mattp's Avatar
Legality depends which state you're in too, as there are subtle variations in the rules. e.g. circumference vs diameter.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2009, 04:24 PM   #21
ebxr82nv
All depends how you define performance doesn't it. It's true that 20s are crap to drive on, more noise and you need to be very careful with pot holes, but I wouldn't define 16s as a performance size wheel on a falcon. Maybe on a small to mid size car but not a falcon. If you wanted the best balance of handleing and ride comfort you would want a 17, just enough side wall to cope with the bumps but not distort excesivly when cornering.
There must be a reason why they still run them on the super cars.
At the end of the day 20s look good and that's about it.
Old 13-03-2011, 02:53 PM   #22
Dragoneletra
Dragoneletra's Avatar
Were you able to get the longer advanti wheel nuts from anywhere ? or bought specially ?
I just got a set of cheap 5 spoke black and silver 19" mags for the XF but the nuts are not long enough for the studs. You cannot tighten them up all the way which sucks. But boy do they look HUGE.
And man do the 35mm spacers now seem really obvious...lol
Jc
visit us @ http://dunwrights.com.au
http://Darwindoorsandgates.com.au
And http://Darwinairconditioningdirect.com.au
BFIII wagon, hoovered, scooped and dropped. Water/meth injected..
Getting the shopping done.....FAST
Build thread:
http://fordforums.com.au/showthread.php?t=11307332
'69 XW Fairmont
bombed 351 cleveland
http://fordforums.com.au/showthread.php?t=11244411
The reason I'll end up divorced
XE FALCON HEARSE build.
http://fordforums.com.au/showthread.php?t=11452342
Dragoneletra is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2011, 05:49 PM   #23
MexicanBatman
MexicanBatman's Avatar
Accelera tyres, the ones you mention are made in Indonesia
Ask the tyre shop where the Continental sport contact 2 are made,
Then tell him to stop talking bull dust and gtfo..
For what it's worth I had them tyres prior to fitting Pzero nero's in 20's on my car
And they were good, BUT.......
They were returned under warranty as they were faulty, the rear tyres would keep going flat, turns out the just wouldn't sit nicely on the rim due to being cheap made indonesian crap, and as I happen to know my tyre guy well, he gave me the nero's for not much more and said this is not the first set of these accelera tyres that's had this problem...
Problems aside, they gripped reasonable, were ok in the wet, and weren't too bad noise wise, in that size they are only worth 200 a corner, I got 275 pirellis for 300 each... So for bugger all more I got a really decent tyre
**edit just realized the op is about 2 years old, but information on the accelerate tyres is still valid, they are a copy of the csc2 tyres, but aren't an exact copy, a parallel import big brand tyre is not much more and loads better if performance is what your after
MexicanBatman is offline   Reply With Quote Multi-Quote with this Post
