Old 11-01-2005, 07:33 PM   #1
EL_futuraistic
EL_futuraistic's Avatar
Default Changing EL from single to LSD
Hey guyz, Couldnt find any area in the tech section, so im posting here.
I have an EL futura, would like to change from non LSD to LSD. Do i require 9" conversion, or a new housing. OR can i simply change crownwheels and drive shafts???
Also what sort of cost would i be looking at??
EL_futuraistic is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2005, 07:42 PM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
Easiest method is to get a LSD from a Ghia/XR/LTD/V8(if optioned). SHould be arround $650ish disc to disc. Otherwise u can buy a new LSD hemisphere ($550ish) and have it fitted.
Old 11-01-2005, 08:13 PM   #3
TUFED6
TUFED6's Avatar
I can recommend Supatrik in Dandenong if you want to get a diff built. He can take a while to turn the job around, but he's reasonably priced.
Has anyone found any tricks to getting good life out of the BTR LSD's? I know all of the ones I've had in the past i've managed to open them up with a few months of opposite lock action.
Apart from using good LSD oil, there doesn't seem to be much that you can do to make them live... Only options really are a Kaaz mechanical LSD (or similar) or a spool. Or the 9in conversion I guess.
- John
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2005, 08:32 PM   #4
Walkinshaw
Two > One
Walkinshaw's Avatar
All LSD's will wear out with prolonged punishment. If your into some hardcore driving look into a Mechanical LSD or Detroit style locker
Old 11-01-2005, 08:50 PM   #5
EL_futuraistic
Default cheers guys
thanks, i will give them a call.
Old 11-01-2005, 09:25 PM   #6
needturbo6
ooga-lagga-ligga-lagga
needturbo6's Avatar
- John
theres a couple of things you can do, my brother stretched the springs on his 4-pinion LSD -302 XA coupe ~240rwHP, its been in many burnout competions and its still goin strong.
another way is by shimming the centre up which basically does the same thing - tightens it up a bit, im gettin one built this way (with 2 extra shims) towards the end of the month. ill let yall know how it goes.
needturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2005, 10:12 PM   #7
Psycho Chicken
Psycho Chicken's Avatar
All extra shims will so is increase the torque needed to slip and burn the cones out faster.
