06-04-2009, 04:32 PM | #1 | ||
too many fords
Whats the best way to remove the badges on the XR8?
Daily driver 1: [COLOR=Indigo] 2010 FG XR6 Turbo 50th Anniversary, BPR CAI, Plazmaman turbo pipe. Daily driver 2: Nissan gq patrol Project 1: XP ute, 351W, c4, 9inch Project 2: XBGS sedan, sunburnt orange and vinyl, original 4spd, 302C. |
06-04-2009, 04:38 PM | #2 | ||
Critical Thinker
Eucalyptus oil.
Pour some on the back of the badge where the adhesive is, let it sit for 10-15mins. Gentle remove with fingers after. Clean surface area with bug & Tar remover. Thats what I did with mine.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
06-04-2009, 06:23 PM | #3 | |||
06-04-2009, 07:52 PM | #4 | ||
Flairs - Truckers Delight
Debadging is for Bogans.
06-04-2009, 08:16 PM | #5 | ||
Now with an AU XR6
^^^ Do you ever have anything positive to say?
Stop chasing me! I don't have any donuts! 1999 AU1 XR6 VCT - Now with a momo steering wheel! Manual - 18" Koya Race Tek's Black with polished lip - Lowered - Series 2 tail lights - Pioneer P80 Head Unit - Clarion Front 6" Splits - JL 5x7's Rear Coaxials - Clarion 4x90w RMS amp - Clarion DPX1800 800w RMS mono - 2 Clarion PXW1251 400w RMS 12" subs Team Deck Chair Member ............ Once you sit down, you'll never stand up. |
06-04-2009, 08:41 PM | #6 | ||
Heat up the badge with a hair dryer on low heat for a few minutes. Then, use some fishing wiring and slide it behind the badge, use a sawing motion if need be or you may need to heat up the badge a little more (essentially the heating loosens up the glue). Presto! You may have adhesive still stuck to the car so in that case i would then use eucalytpus oil on a rag and apply some elbow grease. I've de-badged my xr6 and it looks very clean and mean - far from bogan!
http://aufalcon.com/THR347 |
06-04-2009, 09:49 PM | #7 | |||
too many fords
06-04-2009, 09:49 PM | #8 | |||
too many fords
Thx mate I'll give that a go
07-04-2009, 12:19 PM | #9 | ||
Hair dryer will work, but I do believe the AU1 the badges were mountedthe old fashioned way. There will be holes under the badge. JC or GK will know more on this. Just a feeling I have.
If this is the case then I don't think a hair dryer will work. |
07-04-2009, 12:50 PM | #10 | |||
The XR and Tickford badges are stuck on with no holes behind them, but the Falcon badge on AU1s has holes behind it.
07-04-2009, 11:52 PM | #11 | ||
I've actually got a S1 so i can confirm that the "falcon" badge does have the holes-behind-the-badge type attachment but it still has glue holding it on and the hair dryer technique does indeed work and i would still highly recommend using this method. See my pics on aufalcon.com, click my signature link below.
Due to the falcon badge on the S1's having holes behind it i used the normal procedure, giving it a blast with the hair dryer to loosen up the glue and then using fishing wire to pry off the badge. Of course the badge is still stuck on because it is still attached to the body through the holes in the bootlid, but this was easily solved by gently pressing the badge out from inside of the boot. It is most likely that the badge stalks that hold the badge in the holes will break but meh! Then it's just a matter of filling the holes with bog, sanding and painting! Schweet... the result? the illusion of a shaved sleeper i suppose?
08-04-2009, 12:06 AM | #12 | ||
SKID IT
i used a screw driver lol. only cause the car was getting painted anyway
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba Where the boost junkies hang out -Forced Ford Forums |
08-04-2009, 12:11 AM | #13 | ||
BlueEyed Terri
08-04-2009, 12:54 PM | #14 | ||
I took the Futura badge off with my thumbnail...
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
08-04-2009, 09:04 PM | #15 | ||
low wagooon
Also Utes have pins in the tail gates on the falcon badge, Was going to remove mine off the xr but found i couldnt
Webby
S2 AU XR6 UTE |
09-04-2009, 02:29 PM | #16 | ||
too many fords
I'll leave the ford badge on just want to get rid of the XR8 badge and the wings for a smoother look
09-04-2009, 02:31 PM | #17 | |||
15-04-2009, 07:01 PM | #18 | |||
I simply cut the badges off using wax dental floss, but fishing line would work also, then sprayed the wax and grease remover, Wipe off paintwork ASAP as is solvent based and you dont wanna damage your paintwork, Then just applied polishing wax and wiped over a couple of times, Came up perfect, no scratches or fade marks. All up only cos about $25. |
16-04-2009, 01:04 PM | #19 | ||
Automotive Detailer
I know my AUII ute has pins behind the Ford badge and Falcon badge.
As suggesed, the best way to remove them is to soak the area in Eucalyptus oil or bug and tar remover. Using fishing line like a saw, cut into the glue/double sided tape behind the badge and either gently pry. Don't use a screwdriver, one slip and you are up for a few dollars. The gunk that's left can be easily cleaned and polished up. |
