21-04-2009, 09:03 AM | #1 | ||
Hurry up Germany!!
Hey
Does anyone know if the USB has a size capacity limit in the new Fiesta Zetec? Thanks Daniel |
21-04-2009, 03:17 PM | #2 | ||
Zetec 09 5 DR in Vision
My 8GB one works fine.
23-04-2009, 11:47 AM | #3 | ||
Hurry up Germany!!
Thanks Candy, I am looking at buying a 32GB stick. Does it say anywhere in the manual about the usb/car's audio player maximum size limit it can read?
Also how well does the GUI work with folders etc when using the USB stick?
2009 WS Fiesta Zetec 5-Door
Color: Vision |
23-04-2009, 01:51 PM | #4 | |||
Will have a look in our manual tonight when I get home. As for the GUI - works really well. Just like navigating with Windows Explorer. Even lists non audio files like pictures (which don't open obviously). Would be kinda nice to be able to display images on the MFD though, even if monochrome |
23-04-2009, 02:11 PM | #5 | ||
Treasure your balls?
Can portable hard drives be plugged in too? Assuming no capacity limitations.
Meteorite T3 TS50 ESS |
23-04-2009, 02:17 PM | #6 | |||
Don't see why it can't as it can access the 120GB drive on our Ipod but maybe it needs an interface for the drive format on portables. Will let you know. |
23-04-2009, 02:25 PM | #7 | ||
Hurry up Germany!!
Very good question hords, I will be awaiting your results Candyman!!
Candyman: Can the GUI read more than 8 characters for folders/file names?
Color: Vision |
23-04-2009, 02:49 PM | #8 | ||
To tell the truth, can't remember mate (didn't notice).
Again, will check tonight. Seem to remember the folder names were cut off short/abbreviated but not sure. Will let you know. |
23-04-2009, 02:50 PM | #9 | ||
Hurry up Germany!!
Color: Vision |
23-04-2009, 10:03 PM | #10 | ||
OK
Shows 15 characters in the file list on the drive. When you select a song it shows the full tag - everything I successfully read mp3's off a portable 120gb HD. Was not able to try a USB drive bigger than my 8GB one as that is the largest I have. Automatically starts playing when you plug the unit in too (either that or it remembered the last track I played ....) Hope that helps |
23-04-2009, 10:23 PM | #11 | ||
Hurry up Germany!!
Woooo ok thanks Candyman.
So your USB hardrive was formatted in NTFS? and is it partitioned at all? and did it read the folder structure just like your USB stick? Cheers!
Color: Vision |
23-04-2009, 10:31 PM | #12 | |||
I'll try our other HD tomorrow but I'm getting nervous about plugging all these powered devices into the USB .... |
23-04-2009, 10:41 PM | #13 | |||
Hurry up Germany!!
Color: Vision |
23-04-2009, 10:45 PM | #14 | ||
I've fried USB ports on notebooks hotswapping HD's :(
24-04-2009, 09:15 AM | #15 | |||
Hurry up Germany!!
Color: Vision |
24-04-2009, 09:28 AM | #16 | ||
You'd think 32gb would be plenty considering thats 8000+ songs!!! LMAO. Thats a lot of time in the car. Probably about 500+ hours, or three weeks. Hahaha
2006 WQ Fiesta Zetec Sea Grey Interior:- MOMO Blue Leather Gear Knob, Window tint, Scuff Plates, ST Black & Blue Leather seats, Soundstream Amp & 5x7 speakers, Sony Headunit, Pioneer sub & Amp. Under the Hood:- Superchips ECU Flash Tune, Denso Iridium plugs, KV85 Magnecor Leads, BMC CDA Induction. Exterior:- Spoiler, clear side repeaters, Lowered (35mm) King Springs, Whiteline 22mm Rear sway bar, 2" cat back exhaust with a dual conversion, Konig 17" Hotswap with Kumho Rubber, HID's. |
24-04-2009, 09:59 AM | #17 | ||
All depends of course on how you rip 'em. My iPod currently has just over 900 songs and has used up 8½ Gb. All my Mp3 are at 320 bit rate.
24-04-2009, 10:04 AM | #18 | |||
24-04-2009, 10:52 AM | #19 | |||
The folders showed up but no MP3's .... Tried the other HD again and all good. I think I'll stick to the Ipod and thumbdrives. As for capacity, my 120gb Ipod is almost full (has a lot of podcasts too though) I have plenty of playlists set up and I'd use most of them during a week. Not all songs are played but I like mixing them up (which is why I use Genius a bit too on the Ipod) so I can see why 32gb thumbdrive would be useful That is what the wife is going to use in the Zetec |
24-04-2009, 01:45 PM | #20 | ||
Hurry up Germany!!
Yeah I rip all mine at 256kbps so the file sizes are fairly large! Hence the need for the largest possible USB stick (at a price!)
Bit weird Candy about the two hard drives tho...
Color: Vision |
