Old 04-07-2009, 07:59 PM   #1
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Default What's killing my starter motors?
I've been having starting issues over the last few months, got the starter motor replaced, all was well for a few months, then the same issues came back, I took it back to the mechanic and they replaced the starter motor under warranty.
This afternoon the starting issues are back again.
What am I missing here?
Holden: If you cant beat them, buy them.
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2009, 08:20 PM   #2
bodes-sh
bad earths? very high compression? dunno, maybe they are dodgy starter motors...
Old 04-07-2009, 08:55 PM   #3
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
The earth should be good and unless I'm cursed with extreme bad luck (wouldn't suprise me) I don't know how I'd get two dodgy starter motors in a row.
How could I tell if it is the compression?
Old 04-07-2009, 08:56 PM   #4
46302ute
gunna get there
46302ute's Avatar
oil leaks maybe?
46302ute is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2009, 09:36 PM   #5
bodes-sh
i wouldn't think compression would be that high that it's killing them. compression test is the best way. i guess the other option is a high torque reduction starter...
Old 08-07-2009, 02:26 PM   #6
brad`
The Monty
brad`'s Avatar
how do u do a compression test?
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2009, 02:40 PM   #7
Jack91
Jack91's Avatar
You put a gauge in the spark plug holes and turn the car over
See link: http://www.geocities.com/dsmgrrrl/FAQs/compression.htm
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2009, 11:09 PM   #8
bodes-sh
how'd you go? any further diagnosis yet?
i'm assuming it's not cranking over for ages before firing? or is it?
Old 08-07-2009, 11:16 PM   #9
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
Not sure if ford electrics a similar to Toyota ( sorry) The alternator regulator was not doing its job and frying his starter motor ,just a thought.
New Owner of a fiesta ST
5 FTR 5 is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 12:54 AM   #10
calais
I had similar issues with a VX Supercharged V6 commodore, recurring starting issues, immobiliser randomly activating during startup, headlight globes blowing often, abs lights and so on. As it turned out after an afternoon of voltmeter detective work, the voltage regulator in the alternator was reading .2 of an amp out of spec and thus was wreaking havoc with the electronics. Each of the three dealerships which the car went into for warranty work replaced large and presumably expensive componentry instead of the true fault... a $5 replacement regulator.
calais is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2009, 06:26 PM   #11
needaXYGT
AU II XR8
needaXYGT's Avatar
so what is the starter motor actualy doing?
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2009, 09:23 PM   #12
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Well it's only done it once, which was when I started this thread, hopefully it was a one off situation... and I haven't driven it much this week so it's hard to tell if it's recurring.
When it happens, the car doesn't even turn over, there's nothing at all.
Old 10-07-2009, 10:16 PM   #13
bodes-sh
i'd say dirty contacts on the starter motor. had this problem with my patrol too, wiggled the main cable from the battery and it has been fine since. it doesn't take much unfortunately, even if it's a new starter, might be worth having a look at.
does it come good itself? or do you need to bash it with a hammer?
Old 10-07-2009, 10:31 PM   #14
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
yeah the hammer works, or sometimes rocking the gear selector back and forward a few times...
I'm wondering if it might be the inhibitor switch as well...
Old 10-07-2009, 10:45 PM   #15
bodes-sh
seems like it with the gear stick. smacking it usually means a stick solenoid. what brand was the new starter, do you know?
Old 10-07-2009, 11:42 PM   #16
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Not a clue! lol
Now that the weekend is here I can have a closer look a things.
Old 11-07-2009, 10:48 AM   #17
b2tf
not here much anymore
b2tf's Avatar
I'd be looking at inhibitor switch and also check that the power steering fluid hasn't dribbled all over the starter motor and buggered up the connections. For the life of me I can't remember where it is on a windsor though, but on the 6's it has the power steering resevoir above it hence why I suggested this.
2024 F150 XLT
Old 11-07-2009, 11:58 AM   #18
svo347
AFF's 1st DM.......
svo347's Avatar
You running aftermarket extractors bud??
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 11-07-2009, 01:14 PM   #19
Stav
Smile
Stav's Avatar
Do what I do.Buy brand new parts from ford and it should last.
Old 11-07-2009, 03:04 PM   #20
bodes-sh
starter, not alternator...
starter is at the rear of the motor, alternator at the front ;)
Old 11-07-2009, 03:49 PM   #21
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Yep I am, I think I know where you're going with this too.
I had an XF with starter motor issues due to the heat coming off the extractors...but I don't think this is the case because I did a 6 hour drive towing a trailer with no problems.
Old 11-07-2009, 03:51 PM   #22
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
I might have to, hopefully this latest issue was a once off, since it hasn't happened again since starting this thread.
