14-07-2009, 03:29 PM | #1 | ||
WNTDAU
iv got an xr6 and i just run normal unleaded petrol. i was wondering if e10 petrol would be ok to run and if it would be better because it has a higher octain level?
aufalcon.com/travz_auxr6 |
14-07-2009, 03:31 PM | #2 | ||
Youl may get a gain compared to 91octane but will use 5-10% more per tank.
14-07-2009, 08:25 PM | #3 | ||
I Wish I Was A Post Whore
Stay away from e10, stuff is no good. My burn cleaner, (cleaning of carbon build up) but I ask you. Where does that carbon go? Have seen a few motors die after switching to e10. Starting to look like blocked oil galleries are common
14-07-2009, 09:14 PM | #4 | ||
Never had a problem in my au 6's as far as e10 itself goes, but rather which brand you choose. In my experience, Caltex is the WORST fuel i've ever used and it will never touch my cars again. Engine wouldn't turn over for at least 3 attempts, idling rough and bad consumption, but the moment i stick BP into it, it runs perfect. Shell is ok too, just usually more expensive here.
14-07-2009, 09:27 PM | #5 | ||
yeh e10 stuffed my cat and melted my oxygen sensor, i was using it for a year, then all of a sudden i had problems right left and centre lol, car was pinging badly, runnin ruff as guts
14-07-2009, 10:15 PM | #6 | |||
I miss my wheelbarrow
Daniel |
14-07-2009, 10:22 PM | #7 | |||
What people do not realize is that Ethanol effectively leans off your Air fuel ratio as the stoichiometric value is totally different. ULP is 14.64:1, while pure ethanol is closer to 9:1. Even 10% can make your AFR's lean off by 0.5:1 effective equivalence, and for those with a speed-density MAP style ECU (like our inline 6), any changes to the combustion process that improves the airflow efficiency into or out of the engine WILL make the car run leaner anyway. Combine that with a modest % of Ethanol and you can soon be running an equivalent AFR at WOT in the order of 13-13.5:1.... that's enough to melt cats, sensors, pistons whatever, and will cause pinging, high temps and eventually, engine failure. If you play with alternative fuels, pay for a tune, or be prepared for issues. Dont blame the fuel, blame the unknowing user. Daniel |
14-07-2009, 10:23 PM | #8 | |||
Teh Baest
I dunno, even if my car wasn't mildly modded and tuned, i still wouldnt trust it! Mine has had nothing but BP Ultimate for the last 2.5 years
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ) |
14-07-2009, 10:26 PM | #9 | ||
Yeah its all to common for people to blame e10 for something that has gone wrong in their car.all its got is a little bit of alcohol added.you dont hear of many problems on new cars only the ones that have been to the moon and back.If people had kept running the same fuel they still may have come into the problem but we will never no so its easy to blame any recent changes.ive used it many times in the wagon and all i get is a little less kms per litre nothing else.
That e85 is some serious stuff when used correctly.Street legal alcohol fuel yeeeeehar! |
14-07-2009, 10:26 PM | #10 | ||||
Daniel |
14-07-2009, 10:32 PM | #11 | |||
Teh Baest
I was trying to teach my yr 12 Chem class about octane ratings and went off on a rant about nitromethane and aviation fuel.. Random, but enjoyable
14-07-2009, 11:07 PM | #12 | |||
80% Ethanol and 20% MaxNos sounds good though!!!!! Daniel |
15-07-2009, 03:21 AM | #13 | ||
The Destroyer
*Lightly off topic*
has anyone used the shell VPower 100?
Toy- Blown XR8 Ute. Black on black "Front-drive cars are for children" |
15-07-2009, 09:41 AM | #14 | ||
Has caught the bug...
Shell Vpower 100 is the only stuff I use, good power and excellent milage from the tank, my XR6 VCT gets about 600km from the tank and I have a heavy right foot.
I wouldnt use anything else, but as stated above if I was running a boost setup I would most likely go for a E10 mix and have it tuned to that. |
