Old 12-08-2007, 12:21 AM   #1
pjb070
Bulletproof 351 Clevo
pjb070's Avatar
Default Who uses Upper Cylinder Lubricant?
Hi - who here uses Upper Cylinder Lubricant, and if so what have your experiences been with various brands?
pjb070 is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2007, 12:45 AM   #2
GK
Walking with God
GK's Avatar
I have both my AUs on LPG, both running Flashlube via the drip feed bottle. It's actually quite hard to compare brands because each uses different bottles and drip rates as some liquids are thinner/thicker than others.
I chose Flashlube because it was first recommended to me, but I like the idea of supporting a product made in my country and hometown. That's another reason I take pride in driving my Falcons, because they're made 10 minutes from my house.
I've spoken a few times to the guys at the flashlube factory and they seem like top blokes, always happy to talk and ask questions. They have a confidence in their product and stack it happily against all others.
As far as the bottle (drip feeder) goes, my neighbour has a Morey's system and whilst I can't fault the performance of the Flashlube system, I liked the Morey's bottle better, as it was smaller and a neater shape, making it easier to attach and tuck away in the engine bay. That aside, I'd go Flashlube.
All the best with your decision.
Also, I buy the lube in 5 Litre containers, soooo much cheaper that way.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 12-08-2007, 12:47 AM   #3
howesy
howesy's Avatar
Why bother. if the engine has a little bit of wear and is not tight then it is unlikely you will get a stuck valve. I just kept running my clevo and thought if the guides wear too excessive or a valve burns out then I will do the heads up and two years down the track after a holed radiator the head gasket went so off came the heads, bigger valves bronze guides and hardened seats and presto its an unleaded clevo cost about 700 for both heads total reco.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2007, 12:48 AM   #4
pjb070
pjb070's Avatar
Thanks GK - do you think the motors last longer and work better with the UCL?
Old 12-08-2007, 09:00 AM   #5
stavros68
dont believe in it, had a AU windsor with 460,000kms on it and still ran fine no miss, pulled the motor out valves are stuffed as you would excpect the rest was in good cond
stavros68 is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2007, 10:13 AM   #6
Fairlane
V8 Powaah
Fairlane's Avatar
Old man used to use Morey's through the feed setup in a FJ60 Landcruiser. Seemed to work well, did 200,000 after the recondition (when it was installed) no problems.
Though i gotta say everyone seems to use Flashlube these days
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2007, 02:05 PM   #7
FGII-XR6
FGII-XR6's Avatar
the guy who fitted my LPG said on the I6 falcon "don't waste your money" some engines need it but the falcon is not one of them. look at all the falcons geting 800 to 900K out of an engine as a taxi with mo flash lube . as i said some do need it but The I6 faclon isn't one of them
Old 12-08-2007, 07:24 PM   #8
GK
Walking with God
GK's Avatar
I'm not sure to be honest. Some in the Know say "don't run LPG without it", others say "don't bother."
I chose it for my vehicles and am happy with it. I guess if nothing else, it gives peace of mind. That's still no guarantee of course! LOL!
Put it this way, it can't hurt!
GK
Now gone!
On LPG
Old 12-08-2007, 07:32 PM   #9
FGII-XR6
FGII-XR6's Avatar
Originally Posted by GK
it can't hurt!
GK
except the wallet that is
Old 12-08-2007, 08:05 PM   #10
GK
Walking with God
GK's Avatar
Quite true!
Everything we discuss and do here has an annoying tendancy to do that, "hurt the wallet!" LOL!
GK
Now gone!
On LPG
Old 12-08-2007, 09:05 PM   #11
pjb070
pjb070's Avatar
The thing is if these types of things (UCL and oil stabiliser etc) do what they claim then you would use them and try to do it is a cost effectively as possible.
Old 14-08-2007, 05:24 PM   #12
sly
Sly like a G6
sly's Avatar
Same here. The shop that fitted my LPG do all the servicing for a fleet of a few dozen taxis. They told me the valves, guides & seats in the I6 are all made of better quality metal than most other engines.
OTOH I have Flashlube in the Courier (which has a thinly-disguised Mit'shi Astron II 2.6) as the gas fitter recommended it for that engine. It seems to work as I haven't had any valve problems in 11 years on LPG.
Sleeper, anyone?
Old 19-08-2007, 03:03 PM   #13
peterban
AULTD
peterban's Avatar
Has anybody fitted it to a V8 Fairlane / LTD ?
I think engine bays are the same though on all the V8's, bugger all room.
I got a brand new Morey's kit cheap off e-bay but there doesn't seem to be any room to fit the bottle.
As for vacuum lines, I can't find any diagrams in the Ellery's work shop manual, (although I can identify them) I don't know what they are powering and it seems that they are one side of the manifold or the other.
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2007, 07:21 PM   #14
smee
FishermanDan
smee's Avatar
The trouble with these systems is that when under load they dont provide protection when the motor needs it most - because there's not much vac to draw the fluid through
smee is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2007, 07:36 PM   #15
peterban
AULTD
peterban's Avatar
I was under the impression that when the lubricant burnt in the combustion process it leaves some residue behind on the valve to protect them and the seats.
Has anyone got a diagram of the vacuum system used in the AU II V8's?
