Old 02-08-2009, 11:23 PM   #1
Teknoslasher
Travis - 1999 Ford AU S1
Teknoslasher's Avatar
Default AU Diff gone, what now?
Hi All.
After a long weekend replacing the front end's wheel arm section thingo, we've realised that my AU's diff is also gone, and probably worse than the front end's problem.
Long story short, anyone know if the EF's diff will go straight in to an AU, as I have one down the back of the yard in the old car?
Cheers.
Teknoslasher is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2009, 11:25 PM   #2
RG
Back to Le Frenchy
RG's Avatar
If they're both live axle then the centres are a direct swap.
Old 02-08-2009, 11:26 PM   #3
Teknoslasher
My father's looking into it tomorrow, but how would I, not technically minded, know if they're both Live Axle?
Old 02-08-2009, 11:28 PM   #4
RG
Back to Le Frenchy
RG's Avatar
What model AU?
Old 02-08-2009, 11:31 PM   #5
Teknoslasher
What model AU?
Series 1 1998 AU Forte and the EF is a 1996 model.
Old 02-08-2009, 11:33 PM   #6
RG
Back to Le Frenchy
RG's Avatar
Then you do have live axle (non IRS) so it is a straight swap of the centres.
Old 02-08-2009, 11:33 PM   #7
frd906
not live axel, as i own a 99 model
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2009, 11:33 PM   #8
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
should be live axle mate.
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2009, 11:39 PM   #9
Teknoslasher
Don't mind my lacking terminology. So we swap the centers, but keep the arms that the axles run through and re-attach them?
Old 03-08-2009, 12:02 AM   #10
JC
JC's Avatar
Why do you continue to show your ignorance; posts like this (yours) throw confusion where there should be none. If it's not an XR, and not a Fairmont Ghia, then it has Live axle (ie solid diff), NOT IRS.
From now on, you should refrain from posting your opinion and presenting it as fact. Either don't post, or preface your post with something like "I don't know this for sure, but I think, or my mate has told me.........."
Teknoslasher - when swapping the centres over, you need to ensure that the gears mesh/lap properly and there's no play etc, so if you're unsure what you're doing, it might be time to take it to a diff specialist to get the work done.
Ford Performance Club ACT
Old 03-08-2009, 12:05 AM   #11
JC
JC's Avatar
Kind of, but not really. The "arms" are attached to the centre part of the diff. This is what is referred to as a live axle because the whole diff moves when you hit a bump; with IRS, in theory, only the axle that cops the bump moves.
RG is talking about the internals when he refers to the "centres". You retain the AU axles but use the E series gears from the centre part of the diff.
Good luck with the swap over.
Old 03-08-2009, 12:19 AM   #12
Teknoslasher
Thanks very much JC, clears it up. My old man knows what to do with pulling it all apart, but had asked me to find out if they'd be the same to avoid the cost of going to the wreckers to buy a second hand one and or removing the old one thinking the ef's would go straight in to it.
Old 03-08-2009, 12:34 AM   #13
JC
JC's Avatar
............My old man knows what to do with pulling it all apart, .............
I can't say the same, but I hope my boys might in 10 years or so!
And pulling apart is generally easy; it's the putting back together I sometimes struggle with.
Old 03-08-2009, 01:38 AM   #14
SLO AU XR8
An EF diff (the entire thing) will bolt straight in aswell, just making your AU have Pre-AU offset
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 01:51 AM   #15
mik
mik's Avatar
don`t forget to check if the ratio`s are the same on the ef diff as on the original(same amount of teeth on the larger gear(crownwheel) and the small one that meshes with it(pinion).
Old 03-08-2009, 08:11 AM   #16
martyauxr8ute
did the au falcon S have irs as well ?
martyauxr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 08:58 AM   #17
RG
Back to Le Frenchy
RG's Avatar
No, the only AU's to get IRS were the XR8, XR6 VCT, Fairmont Ghia & Fairlane...although I think I may be missing one from that list.
Old 03-08-2009, 10:59 AM   #18
brad`
The Monty
brad`'s Avatar
series 1 fairmont ghias were optional and you forgot T-series :P
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2009, 11:06 AM   #19
GK
Walking with God
GK's Avatar
Yep, then we can sit back, maybe cook the barbie, whilst the boys work on both our vehicles! LOL!
Glad I'm not the only one with the putting back togeter bit!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 03-08-2009, 11:06 AM   #20
RG
Back to Le Frenchy
RG's Avatar
I knew there was something amiss.
Old 03-08-2009, 06:49 PM   #21
au11futura
au11futura's Avatar
GK
lol yeh then they can come and do mine.
It sucks when you've done it so many times and it becomes not fun anymore, mabey i should stick to one car lol...........
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 03-08-2009, 06:52 PM   #22
au11futura
au11futura's Avatar
thats why i stuck out of this one to many people think they know because someone told them so.
some people need to read gregory's more often and become familiar with their cars.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 03-08-2009, 06:54 PM   #23
au11futura
au11futura's Avatar
also mate when doing things such as diff make sure you buy new bearings and shims its always good to know you have replaced things like that just for piece of mind.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 04-08-2009, 09:05 PM   #24
Teknoslasher
Well, at this point we have some good news. I've managed to pick up a diff from another forte, as well as the tail shaft. Best part is, its for free after some great business talking from my old man. They're apparently in really good nick, so fingers crossed all will be well.
Old 04-08-2009, 11:20 PM   #25
au11futura
au11futura's Avatar
well done mate keep us posted.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 04-02-2012, 06:01 AM   #26
grime
Default Re: AU Diff gone, what now?
I would like to drop an LSD centre into bog standard au2 live axle futura sedan to help with towing etc.
On ebay I can get a reco 28spline lsd hemi and the seller informs me that all I will need to do is "use your crownwheel gear off your original hemi & bolt it on to the lsd hemi"
So,is it that easy?
Are there any pitfalls apart from changing the oil to LS90?
grime is offline   Reply With Quote Multi-Quote with this Post
