11-11-2009, 09:01 AM | #1 | ||
may be a dumb question but, how do you work out the lead placment on the twin V8 coil packs? of course you take off one lead at a time, however if you were handed the coils and leads how would you work it out?
11-11-2009, 10:52 AM | #2 | |||
AU DIE HARD
Wait till I get home and take the engine cover off and post a picky if you like :
11-11-2009, 11:16 AM | #3 | ||
[ 5L ]
about 95% sure this is right lol, its bloody hot outside and i only turned my car off bout half hour ago. the way ive bunched the leads up on the passenger side its hard to tell where they go to as there crossed over each other.
the sequence on each side of the motor drivers side starting from front 1 2 3 4 passenger side starting from front 5 6 7 8
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
11-11-2009, 11:22 AM | #4 | |||
Back to Le Frenchy
If they are original Motorcraft coils the lead placement is printed on them. Pots 1-4 are drivers side front to back and 5-8 passenger side front to back.
I'll try to chase up the correct coil placement for you. EDIT: Looks like 5L has sorted it, from memory that looks correct.
11-11-2009, 11:29 AM | #5 | ||
[ 5L ]
i think i might of stuffed up the picture above,
ill wait for someone else to verify. maybe i stuffed mine up when changing mine and been driving it since :
11-11-2009, 06:58 PM | #6 | ||||
AU DIE HARD
8 2 6 1.. to rear drivers side to passengers 4 7 3 5 .....................................4 7 3 5 .................................................. .......... .....................................8 2 6 1................................................. ......... factory coils and TG numbered Blue leads
11-11-2009, 07:16 PM | #7 | ||
[ 5L ]
yeah im fairly sure that is what mine is running whoosha, i only had a quick look.
ill go check to be sure though ahaha.
11-11-2009, 07:28 PM | #8 | |||
AU DIE HARD
11-11-2009, 07:33 PM | #9 | ||
Afterburner + skids =
Here you go chaps
http://fordforums.com.au/vbportal/mo...article&id=308 amiers, don't worry, it isn't that embarrassing
11-11-2009, 07:37 PM | #10 | ||
[ 5L ]
i dont know how i wrote down the wrong numbers. just checked and mine is right ;)
11-11-2009, 08:08 PM | #11 | ||
Thanks guys. so plug lead #1 goes to the 1st plug on the drivers side at the firewall? my leads are numbered and from the front of the car starting at the drivers side rear(nearest to firewall) its 1,2,3,4 then 5(behind power steer).6.7.8
11-11-2009, 08:26 PM | #12 | ||||
AU DIE HARD
11-11-2009, 08:48 PM | #13 | ||
As per the above diagram that I posted.
