Old 15-11-2009, 12:16 PM   #1
sd1800
Default Removing Rear Seat Belts
Currently having a few issues in trying to remove the rear left seat belt. Basically it is rooted and will no longer retract. I am trying to get it out to see if something i jamming it and if not will have to replace.
I removed the plastic on the inside of the C Pillar but can't work out where the actual belt unit is bolted in and how to get it out??
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2009, 12:53 PM   #2
FTe_XR8
formerly "3x-puursui7"
you need to removed the bottom of the rear seat, just pull up at the front on the left and right side of the seat, the bottom bolt for the belt is under the back seat, and i think the reel is under the side bolster or just under the parcel shelf, you may need to fold the back seat down then unclip the trim in the boot.
all hail the mighty V8's
http://www.aufalcon.com.au/3x-puursui7
FTe_XR8 is offline   Reply With Quote Multi-Quote with this Post
