Old 06-12-2009, 07:51 PM   #1
lotus
Default BF rear brakes on AU
Just wanted to know if the rear brakes off a BF XR8/Turbo (vented) will fit on an AU1 IRS.If they can,I would suspect that the calipers would be different to make up for the thicker rotor.
We salute those brave souls that enter the DARK side
lotus is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2009, 08:46 PM   #2
The Monty
Just slidin'
The Monty's Avatar
Calipers, pads (obviously) and rotors, but are bolt on, no mods necessary. 303mm iirc.
I run BA/F fronts, same deal there, 298mm rotor, caliper and pads, bolt straight on.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 06-12-2009, 09:45 PM   #3
InfernoSR
Sales Representative
InfernoSR's Avatar
I didnt think you could add AU2-3/Bseries onto AU1's without upgrading other parts...
Old 06-12-2009, 09:52 PM   #4
private9
www.TUFFCARPARTS.com
private9's Avatar
That's correct for the front.
Old 06-12-2009, 10:28 PM   #5
InfernoSR
InfernoSR's Avatar
Atleast i got that half right... lol! :
Old 06-12-2009, 11:18 PM   #6
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
BFXR8/XR6T rears are bigger than BA, 328mm iirc
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2009, 11:29 PM   #7
lotus
That's why I want to know if they will fit as I have a 330mm front brake upgrade for the SER1 and was looking at fitting the BF's on the rear.
Old 06-12-2009, 11:33 PM   #8
chief
FTF Club Moderator
chief's Avatar
You made need to space the rear calipers a fraction away from the hub mounts. I did with my rear brake upgrade (albeit a live axle wagon), but I have heard from many people including Race Brakes say that you need to if putting B series rear brakes on an AU. A 2mm - 3mm washer between the caliper and hub is enough.
The reason is that the caliper hits the disc other wise.
Albert Einstein:
Fords in the Park 2010
Old 07-12-2009, 12:18 AM   #9
InfernoSR
InfernoSR's Avatar
Had that same problem in the back of mine when i put Terri rear calipers in my SR with the solid rear axle...
Old 07-12-2009, 04:40 AM   #10
The Monty
Just slidin'
The Monty's Avatar
Man, thats the worst info Ive ever given out, didnt read the series one bit, sorry guys.
Old 07-12-2009, 11:12 AM   #11
lotus
Could a bracket/plate be made instead of using washers to fit these calipers?
Does anyone know of someone who might be able to make these up or is it a "do it yourself" job?
