Old 11-12-2009, 10:16 AM   #1
all4fordau
Default Welding precautions AU3
I just want to know what everyone does when using an electric welder on their cars? I want to do a small job on the exhaust pipe using an arc welder. I know that on older cars prior to electronics that you just disconnected the battery and all was ok. With the modern electronics, is there anything else that needs to be disconnected prior to welding, such as the ecu or anything else???
I dont want to stuff up the electronics. :togo:
all4fordau is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2009, 10:30 AM   #2
Karnage
Finger Painter
Karnage's Avatar
Yup just disconnect the battery and you'll be fine.
Karnage is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2009, 05:27 PM   #3
frd906
ummm, when my exhuast guy did my exhuast he didnt dissconect the battery
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2009, 05:42 PM   #4
Trace 347c
Trace 347c's Avatar
Disconnect the negative terminal mate, its what we do at work
Trace 347c is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2009, 06:22 PM   #5
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Most exhaust shops connect a surge protector to the battery.
Saves a customer from re entering the security pin for radio and so forth.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2009, 06:25 PM   #6
Stattic
Stattic's Avatar
exhaust shops also dont use arc welders..
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2009, 06:26 PM   #7
frd906
unless my exhaust guy has a surge protector either on the mig welder on the earth lead it seld, he just drove my car on to the hoist, put it up and started weldeing the exhuast on
Old 11-12-2009, 07:53 PM   #8
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
I've welded on cars before with the battery connected. Just because you can do it doesn't make it a good idea. Disconnection of the battery is a very good idea as is a surge protector if you have one.
Old 11-12-2009, 08:01 PM   #9
NC1183
NC1183's Avatar
Yeah, with MIG welders, if you have the earth lead right at the job your safe. I wouldn't try it with a stick welder but
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
