Old 12-12-2009, 10:36 PM   #1
den
Default Replacement diff
Just a quick question for you guys, Will a diff from a XH ute fit an AU ute?
Would it be a easy change out?
den is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2009, 11:22 PM   #2
rhysieboyy
i wouldnt think so maybe but has the au got live axle or irs?
rhysieboyy is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2009, 11:37 PM   #3
Stattic
Stattic's Avatar
the utes have live axle. you could swap the centres, they might not be a perfectly straight fit (might need shims) but the whole diff e.g disc to disc will not fit
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2009, 06:23 AM   #4
den
Ok, thanks for the info. The search continues.
Old 13-12-2009, 11:26 AM   #5
SLO AU XR8
Ute to Ute will swap, but then you will need E-Series offset rear wheels and standard AU on the front
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2009, 02:11 PM   #6
Stattic
Stattic's Avatar
would that handle a bit strange?
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
