Old 22-01-2010, 10:47 PM   #1
brad`
The Monty
brad`'s Avatar
Default Brembos for a series II Fairmont question
Ok so i know FG/BA/Bf brakes fit series II and on wards but i was wondering if Brembos fit series II Fairmont's with out much hassle?
cheers
brad`
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2010, 11:00 PM   #2
blownv8au
Pro Street Au Ute
blownv8au's Avatar
they should fit no problem, all au 2&3 are the same except premium brakes but they all have the same stub axle and will accept brembos. but you will have to find wheels to fit over them. alot of the wheels i like won't fit over them i haven't got the brembos yet but will be down the track so i have to get wheels that fit.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2010, 11:03 PM   #3
brad`
The Monty
brad`'s Avatar
its for a mates car.. he is running 19x8 copies of the GT rims and they are 6 pot brembos not 4 pot, does that change n e thing?
Old 22-01-2010, 11:06 PM   #4
FTe342
FTe342's Avatar
No any wheel that fits over the 4 pots will fit the 6 pots
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2010, 11:08 PM   #5
The G6ET Spot
6 pot will still fit behind those wheels. But a quick word of warning, front brembos for FG's ahve a different mounting bracket than BA-BF-AU11-111
The G6ET Spot is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2010, 11:10 PM   #6
AU1XLS
AU1XLS's Avatar
Just watch the placement of wheel balancing weights
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2010, 11:49 PM   #7
brad`
The Monty
brad`'s Avatar
well in saying that if they are of an FG how hard would it be to change the mounting bracket? or could u still use the origional AUII bracket and just modify that?
Old 23-01-2010, 01:04 AM   #8
blownv8au
Pro Street Au Ute
blownv8au's Avatar
what au2 bracket do you mean? brembo one?. i have read on hear that the fg bracket just needs to be spun around 180 degrees someone correct me if i'm wrong please.
Old 23-01-2010, 02:09 PM   #9
brad`
The Monty
brad`'s Avatar
nah just the stock series II non premium ones
Old 23-01-2010, 02:15 PM   #10
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
You'll need the correct size and offset rotors as well. Brembos won't just bolt up over the standard rotors.
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2010, 05:48 PM   #11
Ride
Stay Classy ™
Ride's Avatar
That's correct, if you spin the bracket around they'll fit fine. Do note though, if you're buying an FG kit (calipers, rotors, lines) you will need longer lines for the AU, the FG's are quite short. Obviously you will need discs to suit and they're a lot cheaper buying in a kit (see Matt from Race Brakes Sydney, he did my 4 + 4 Brembos for my Fairmont Ghia).
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2010, 10:16 PM   #12
xrford
WAGONE
xrford's Avatar
I think i just left the brackets on there and put the left rotor on the right side and right on the left....just incase you didnt want to spend the 5 mins swapping them around tho.
xrford is offline   Reply With Quote Multi-Quote with this Post
