I have a 2010 Lx Focus i think i saw the side mirrors which if iam not mistaken on the xr5 turbo my question is can i buy the xr5 mirrors because they have the special mirrors for ur blind spot instead of buying those stick on ones.
If anyone can help will be appreciated Cheers |
You mad, bro?
Yep, the XR5 mirrors do have the blindspot section for both sides. In terms of fitting them, i'm not 100% sure. The XR5 mirrors have the indicators and heating also.
Anyone actually done this?
2009 LV Focus XR5 Turbo Performance Blue SFS 2007 Best Cougar, SFS 2010/2011 Best Focus XR5
Yes it is mine...
If the external dimensions of the mirror are the same, then fitting should not be a problem.
In most cases the mirror part is glued onto a plastic section which is attached to the motor arm. You should be able to remove the currently installed mirror and install the XR5 mirrors. or Give Athol Park Ford Spares a ring. They have a white LV XR5 wrecking at the moment |
