16-05-2010, 10:45 PM | #1 | ||
anyone recommend roof lining repairer in Brisbane? How much?
16-05-2010, 10:47 PM | #2 | ||
Moorooka auto trimmers. $130 and they do it while you wait.
Cant remember the number, Its on a bit of paper in my tool box at work so i will get it tomorrow.
AU XLS. |
16-05-2010, 10:50 PM | #3 | ||
Mine cost me 90 bucks from a place in Beaudesert
16-05-2010, 10:58 PM | #4 | ||
thx guys!!
24-05-2010, 06:42 PM | #5 | ||
Do they remove the original ************ grey material and replace it over your existing backing or are they a full replacement?
1983 Bahama Biege XE S pac manual. 2006 Octane BF XR6 Turbo Sedan 2005 White Courier Dual Cab |
24-05-2010, 06:53 PM | #6 | ||
Loving my '335' kW!
The trick is to get it when it starts to come away at the corners. Let it go and it gets bad really quick. I just use a dab of glue to stick it back into place, and you can't tell. If it goes further than that though, you are up for the full treatment.
FG X XR8 in Smoke. Smokin the tyres, that is! XR8 logo pic taken at Avalon Airport, Falcon Fanatic filming 17th October 2014 |
26-05-2010, 06:16 PM | #7 | |||
I'll have to look into this place at Moorooka, sounds like the go.
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
26-05-2010, 08:20 PM | #8 | ||
When they redo the hoodlining do they use a similar material to original? Am after a black one to match the trim but dont really want to pay big dollars for a trim shop to do a custom one if i can avoid it.
28-05-2010, 08:54 PM | #9 | ||
AUssie2ooo
Mine was coming away at the edge across the windscreen. I used the wifes' heavy duty hairspray. It has been holding for about 4 months so far. I didn't have the money at the time for a new lining, and now that I have the money, the bugger hasn't let go....Touch Wood...........(hope the wife doesn't read this)
AUssie2ooo : |
28-05-2010, 11:01 PM | #10 | ||
All Bran = Regular Member
Mine started to droop along the rear window.
All I had was some "No More Nails" so smeared a bit along the rear edge, pushed the lining back up and two years later it's still there |
05-09-2011, 10:21 AM | #11 | |||
Do you remember the name of the business? I'm getting quotes for around $200, so 90 bucks sounds like a bargain! |
05-09-2011, 10:31 AM | #12 | |||
I just called these guys, they quoted me $275 and it apparently takes 4 hours! (5 door hatch without a sunroof). Seems their prices have inflated a bit in the past year or so... |
05-09-2011, 03:57 PM | #13 | |||
05-09-2011, 04:02 PM | #14 | ||
Try Mota Trim, South Tweed Heads, Ph 0409 268 449.
They have a mobile service too. Job done on my car, that cost $150, is shown here: http://www.fordforums.com.au/showpos...&postcount=197
05-09-2011, 04:07 PM | #15 | ||
i used to be a trimmer when i was 16, the technique is to remove the material (fabric, whatever) then you use a wire brush, and your hands etc to physically remove all the glue left on the board, (it just crumbs off in little peices) once completely clean (no, you wont get ALL the glue off, just all the big/loose bits)
you spray on new glue, just contact adhesive (whether in a gun, or can) let it sit for about 10-30seconds, then spray some on the back of the new material you have, then with 1 or 2 people helping you, lay it down onto the board firmly and evenly, push all the bits like for the sunvisors etc (the fabric will stretch, and the glue will hold it into place to hug the curves) then get a knife and trim off all excess. job done! its literally that easy. no special techniques, etc. (though this is as far as i am aware.. there might actually be different ways to do it lol :P) |
05-09-2011, 04:08 PM | #16 | ||
forgot the first step, (debatebly obvious) remove the head lining (NOT called roof lining) and rest it on the floor material face up.
